I'd like to take 10-15 Gb MKV / M2TS files (mix of 1080P24 / 1080i60 video and AC3/DD2.0/DTS audio) and burn them onto a pair of DL-DVDs so that they can playback on a PS3 as a simple load and press play 'movie'.
Specific examples are 12Gb 1080i60/DD2.0 m2ts and 14.5Gb 1080P24/DTS.
Is there anything that can split the files, remux (not transcode) and create the appropriate stuctures automatically?
check out multiavchd. It should do what you want with a little exploration.
However your dts might be an issue. Also I don't know about the 60 and 24 aspect.
Check that - I think multiavchd will reencode to avchd if its not to spec. I don't know the full spec for avchd.
What you could try is something like tsmuxer and go from there. THan burn to verbatim dual layer discs with imgburn.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
Problem converting bluray into split avchd (for hdd fat32 and ps3)
By Ale_Strife in forum Blu-ray RippingReplies: 5Last Post: 18th Feb 2011, 04:04 -
Software to split 10GB Blu-Ray File for the PS3
By Euroconvert in forum Video ConversionReplies: 7Last Post: 2nd Jan 2011, 16:48 -
Convert movies from my ipod touch to PS3 and DVD Player
By d_unbeliever in forum Video ConversionReplies: 5Last Post: 13th Jun 2009, 07:05 -
Possible to create a hybrid AVCHD disc with DVD-Video on DVD-R for PS3?
By siegeknife in forum DVD RippingReplies: 5Last Post: 24th Oct 2008, 11:22 -
i need to split m2ts files for PS3
By domerdel in forum EditingReplies: 6Last Post: 11th Nov 2007, 02:36
