Page 9 of 12
FirstFirst ... 7 8 9 10 11 ... LastLast
Results 241 to 270 of 349
  1. Originally Posted by jackmonter5 View Post
    getting error
    C:\Temp>livestreamer "Referer: http://bhol.cdnwiz.com/html5/html5lib/v2.25/modules/EmbedPlayer/binPlayers/kaltura-player/kdp3.swf" "hds://http://video.bhol.co.il/p/103/sp/10300/serveFlavor/entryId/0_n370gnre/v/2/flavorId/0_,8zeycsep,c0qfssop,ycceo41c,/forceproxy/true/name/a.mp4.urlset/manifest.f4m" best -o video.flv
    usage: livestreamer [OPTIONS] [URL] [STREAM]
    livestreamer: error: unrecognized arguments: best
    C:\Temp>livestreamer "Referer: http://bhol.cdnwiz.com/html5/html5lib/v2.25/modules/EmbedPlayer/binPlayers/kaltura-player/kdp3.swf" "hds://http://video.bhol.co.il/p/103/sp/10300/serveFlavor/entryId/0_n370gnre/v/2/flavorId/0_,8zeycsep,c0qfssop,ycceo41c,/forceproxy/true/name/a.mp4.urlset/manifest.f4m" -o video.flv
    error: No plugin can handle URL: Referer: http://bhol.cdnwiz.com/html5/html5lib/v2.25/modules/EmbedPlayer/binPlayers/kaltura-player/kdp3.swf
    oops sorry bad code
    livestreamer  --http-header "Referer=http://bhol.cdnwiz.com/html5/html5lib/v2.25/modules/EmbedPlayer/binPlayers/kaltura-player/kdp3.swf"  "hds://http://video.bhol.co.il/p/103/sp/10300/serveFlavor/entryId/0_n370gnre/v/2/flavorId/0_,8zeycsep,c0qfssop,ycceo41c,/forceproxy/true/name/a.mp4.urlset/manifest.f4m" best -o video.flv
  2. thanks so much, but still error
    C:\Temp>livestreamer --http-header "Referer=http://bhol.cdnwiz.com/html5/html5lib/v2.25/modules/EmbedPlayer/binPlayers/kaltura-player/kdp3.swf" "hds://http://video.bhol.co.il/p/103/sp/10300/serveFlavor/entryId/0_n370gnre/v/2/flavorId/0_,8zeycsep,c0qfssop,ycceo41c,/forceproxy/true/name/a.mp4.urlset/manifest.f4m" best -o video.flv
    [cli][info] Found matching plugin stream for URL hds://http://video.bhol.co.il/p/103/sp/10300/serveFlavor/entryId/0_n370gnre/v/2/flavorId/0_,8zeycsep,c0qfssop,ycceo41c,/forceproxy/true/name/a.mp4.urlset/manifest.f4m
    [cli][info] Available streams: 272p (worst), 360p, 720p (best)
    [cli][info] Opening stream: 720p (hds)
    [download][video.flv] Written 3.2 MB (24s @ 134.9 KB/s) [stream.hds][error] Failed to parse fragment 1-3: End of stream before required data could be read
    [stream.hds][error] Failed to parse fragment 1-4: End of stream before required data could be read
    [stream.hds][error] Failed to parse fragment 1-5: End of stream before required data could be read
    [stream.hds][error] Failed to parse fragment 1-6: End of stream before required data could be read
    [stream.hds][error] Failed to parse fragment 1-7: End of stream before required data could be read
    [stream.hds][error] Failed to parse fragment 1-8: End of stream before required data could be read
    [stream.hds][error] Failed to parse fragment 1-9: End of stream before required data could be read
    [stream.hds][error] Failed to parse fragment 1-10: End of stream before required data could be read
    [stream.hds][error] Failed to parse fragment 1-11: End of stream before required data could be read
    [stream.hds][error] Failed to parse fragment 1-12: End of stream before required data could be read
    [stream.hds][error] Failed to parse fragment 1-13: End of stream before required data could be read
    [stream.hds][error] Failed to parse fragment 1-14: End of stream before required data could be read
    [stream.hds][error] Failed to parse fragment 1-15: End of stream before required data could be read
    [stream.hds][error] Failed to parse fragment 1-16: End of stream before required data could be read
    [stream.hds][error] Failed to parse fragment 1-17: End of stream before required data could be read
    [stream.hds][error] Failed to parse fragment 1-18: End of stream before required data could be read
    [stream.hds][error] Failed to parse fragment 1-19: End of stream before required data could be read
    [stream.hds][error] Failed to parse fragment 1-20: End of stream before required data could be read
    [stream.hds][error] Failed to parse fragment 1-21: End of stream before required data could be read
    [stream.hds][error] Failed to parse fragment 1-22: End of stream before required data could be read
    [download][video.flv] Written 9.6 MB (1m33s @ 104.7 KB/s) [stream.hds][error] Failed to parse fragment 1-25: End of stream before required data could be read
    [stream.hds][error] Failed to parse fragment 1-26: End of stream before required data could be read
    [stream.hds][error] Failed to parse fragment 1-27: End of stream before required data could be read
    [stream.hds][error] Failed to parse fragment 1-28: End of stream before required data could be read
    [stream.hds][error] Failed to parse fragment 1-29: End of stream before required data could be read
    [stream.hds][error] Failed to parse fragment 1-30: End of stream before required data could be read
    [stream.hds][error] Failed to parse fragment 1-31: End of stream before required data could be read
    [stream.hds][error] Failed to parse fragment 1-32: End of stream before required data could be read
    [stream.hds][error] Failed to parse fragment 1-33: End of stream before required data could be read
    [stream.hds][error] Failed to parse fragment 1-34: End of stream before required data could be read
    [stream.hds][error] Failed to parse fragment 1-35: End of stream before required data could be read
    [stream.hds][error] Failed to parse fragment 1-36: End of stream before required data could be read
    [stream.hds][error] Failed to parse fragment 1-37: End of stream before required data could be read
    [stream.hds][error] Failed to parse fragment 1-38: End of stream before required data could be read
    [stream.hds][error] Failed to parse fragment 1-39: End of stream before required data could be read
    [stream.hds][error] Failed to parse fragment 1-40: End of stream before required data could be read
    [cli][info] Stream ended
  3. Originally Posted by jackmonter5 View Post
    ok try with direct link
    http://bholcdn.cdnwiz.com/p/103/sp/10300/serveFlavor/entryId/0_n370gnre/v/2/flavorId/0_ycceo41c/name/a.mp4
  4. yes that works! how can i decode the url for the future?
  5. Originally Posted by jackmonter5 View Post
    best quality
  6. thanks so much!
    if you don't mind i have one more request,
    this site shows youtube but blocks the url so i can only see lowest quality, and can't download (not knowing url) can you help me how to unhide the URL.
    here is example
    http://bshch.blogspot.co.il/2015/08/blog-post_3588.html
    thanks again!
  7. Originally Posted by jackmonter5 View Post
    thanks so much!
    here is example
    thanks again!
    yes low 320 x 240 ~ 4.1 Mo i think it's the single quality
  8. is there a way to see the youtube url?
  9. Thanks for all your help!
    i have a new request:
    http://www.breslev.co.il/vod/judaism_and_halacha/judaism_and_halacha/vitamin_e_breslev...nguage=english
    C:\Temp>livestreamer "hls://http://212.235.57.53/hds3-vod/English/rabbi_lazer_brody/086_behaalotecha/shiur/1200.f4vSeg1-Frag8" best -o a.mp4
    [cli][info] Found matching plugin stream for URL hls://http://212.235.57.53/hds3-vod/English/rabbi_lazer_brody/086_behaalotecha/shiur/1200.f4vSeg1-Frag8
    [cli][info] Available streams: live (worst, best)
    [cli][info] Opening stream: live (hls)
    [cli][error] Could not open stream: Missing #EXTM3U header
    C:\Temp>livestreamer "hds://http://212.235.57.53/hds3-vod/English/rabbi_lazer_brody/086_behaalotecha/shiur/1200.f4vSeg1-Frag8" best -o a.mp4
    [cli][info] Found matching plugin stream for URL hds://http://212.235.57.53/hds3-vod/English/rabbi_lazer_brody/086_behaalotecha/shiur/1200.f4vSeg1-Frag8
    error: Unable to parse manifest XML: not well-formed (invalid token): line 1, column 0 ('\x00\x00\x00Uafra\x00\x00\x00\x00\ ...)
  10. Originally Posted by jackmonter5 View Post
    hds protocol>>>.f4m
    hls protocol >>>.m3u8
    livestreamer "hds://http://212.235.57.53/vod/English/rabbi_lazer_brody/086_behaalotecha/shiur/manifest.f4m" best  -o video-hds.flv
    livestreamer "hlsvariant://http://212.235.57.53/vod/English/rabbi_lazer_brody/086_behaalotecha/shiur/manifest.m3u8" best -o video-hls.ts
  11. Hi
    I try to download this stream:
    http://www.3plus.tv/episode/bauer-ledig-sucht/staffel-11-folge-01
    But the request end in this message:
    livestreamer>livestreamer "http://www.3plus.tv/episode/bauer-ledig-sucht/staffel-11-folge-01"
    error: No plugin can handle URL: http://www.3plus.tv/episode/bauer-ledig-sucht/staffel-11-folge-01
    Can you help me?
    Thank you
  12. Originally Posted by MarieCroccant View Post
    Hi
    Can you help me?
    Thank you
    hi
    livestreamer "hds://https://sdn-global-http-cache.3qsdn.com/vod/_definst_/smil:2377/files/15/07/341452/341452_vCDjJZbXr76mQWnk.smil/manifest.f4m" best -o "staffel-11-folge-01.flv"
    or
    direct link
    https://sdn-global-prog-cache.3qsdn.com/2377/files/15/07/341452/2-z2MVnK6hW9XfJTmb.mp4
  13. Hi biezom
    Wow, thank you very much for this ultra fast answer. How did you get the direct link?
  14. Originally Posted by MarieCroccant View Post
    Hi biezom
    tools: firefox; adblockplus addon
    so
    http://playout.3qsdn.com/a17038b5-2a5d-11e5-ac5e-0cc47a188158?&js=true
    with in red the pid of the video (you can find this pid in source page code)
  15. Originally Posted by CristianoA View Post
    youtube-dl works for bbc.co.uk
  16. Originally Posted by biezom View Post
    yeah but i can't find any working UK proxy
  17. Originally Posted by CristianoA View Post
    youtube-dl -g --proxy "178.79.129.171:3128"  "http://www.bbc.co.uk/iplayer/episode/b0698dxp/dragons-den-series-13-episode-8"
  18. Originally Posted by biezom View Post
    thanks
  19. Originally Posted by biezom View Post
    Hi biezom
    [Attachment 33353 - Click to enlarge]
    so
    Thank you biezom, you are amazing.
  20. Originally Posted by biezom View Post
    Originally Posted by MarcoLamis View Post
    Genius!!!
    Can you explain how to get the "hls link"?
    i use firefox and user agent switcher addon
    i import list from here http://techpatterns.com/forums/about304.html
    and switch to "browsers linux" "Firefox 32.0 (32 bit)"
    Hi Biezom,
    I've a problem with this movie link: http://www.mymovies.it/film/2014/findingfela/live/?t=vod
    The "user agent linux FF32" trick doesn't work
    Thanks.
  21. Originally Posted by MarcoLamis View Post
    Genius!!!
    Hi Biezom,
    Thanks.
    apparently the stream exist just on HDS encrypted protocol
  22. Thanks Biezom,
    so there is no way to capture the video
  23. This has to be one of the most helpful forums on the web.
    There is a film I'm trying to get from BFI Player to view offline:
    http://player.bfi.org.uk/film/watch-fishermen-1959/
    I looked at View Source and it seems to use a SWF player.
    I then ran URL Sniffer and the manifest URL appears to be
    http://player.ooyala.com/static/cacheable/a1e42d9ec723dfe4c934cf72828b8297/player_v2.s...0e90d730dbd92/[[DYNAMIC]]/2
    But I can't work out how to create the actual manifest to download the file using AdobeHDS.php Please can some one help?
    Many thanks - SB
  24. Originally Posted by SByers666 View Post
    Many thanks - SB
    php AdobeHDS.php --manifest "http://ak.c.ooyala.com/Yxa2djczpsSkxBnCYgjIJVJmOo3ZTf8Y/Yxa2djczpsSkxBnCYgjIJVJmOo3ZTf8Y_1.f4m" --delete --outfile fishermen-1959.flv
    or
    livestreamer "hds://http://ak.c.ooyala.com/Yxa2djczpsSkxBnCYgjIJVJmOo3ZTf8Y/Yxa2djczpsSkxBnCYgjIJVJmOo3ZTf8Y_1.f4m" best -o fishermen-1959.flv
  25. Oh wow!!! Many thanks for the rapid response!!! I wasn't anywhere near the manifest code!!! SB
  26. SByers666, the Firefox extension "HDS Link Detector" is what you need. You just need to append "--outfile filename.flv" to the code that it generates (without the quotes) and then paste that into the command window. Also, Internet Download Manager works for the videos on bfi.org.
  27. Hi,
    I am trying to use Adobehds.php to merge f4f fragments, but I am getting the dreaded "Could not open input file: AdobeHDS.php" error.
    I have downloaded all the f4f fragments I need through downthemall in firefox, so I want to merge the files using Adobehds.php. I actually purchased a copy Bigsoft Video Downloader to merge the fragments, but the Bigsoft software is so buddy and slow that I think Adobehds.php must be better.
    I was able to install Adobehds.php from github and I have been successful at running php -v. When I do that, I get this result:
    C:\>php -v
    PHP 5.6.13 (cli) (built: Sep 3 2015 15:14:39)
    Copyright (c) 1997-2015 The PHP Group
    Zend Engine v2.6.0, Copyright (c) 1998-2015 Zend Technologies
    I can also run php --helper.
    But when I try to do most anything else, including using a manifest switch (php AdobeHDS.php --manifest "your_manifest_url" --delete), I just get the "Could not open input file: AdobeHDS.php" error.
    I have downloaded the most recent AdobeHDS.php and installed it in my C:\PHP folder. I also tried running PHP with the apache server turned on. Nothing worked.
    Has anyone found a solution to this error? It seems to be very common.
  28. I can't promise this will solve all your problems but have you tried using the Firefox extension HDS Link Detector?
    https://addons.mozilla.org/en-GB/firefox/addon/hds-link-detector/?src=api
    To use it you click its icon so it turns red then visit whatever video site and play the video. If it detects the necessary info it will pop up a text box at the bottom of your browser which you click on to copy the code to your clipboard. You can then append to its code (space) --outfile yourvideoname.flv (as an example) and press enter. You might have to be swift about pasting the code as with some sites the code expires after a short time. (I find it useful to paste --outfile yourvideoname.flv into the CMD window then backspace the cursor so it in the right position ready to enter the generated code)
    A simple example would be:
    php AdobeHDS.php --manifest "http://ak.c.ooyala.com/Yxa2djczpsSkxBnCYgjIJVJmOo3ZTf8Y/Yxa2djczpsSkxBnCYgjIJVJmOo3ZTf8Y_1.f4m" --delete --outfile somefile.flv
  29. Thanks for your reply.
    I have tried HDS Link Detector, but it still get the same error:
    "C:\>php AdobeHDS.php --manifest "http://ak.c.ooyala.com/Yxa2djczpsSkxBnCYgjIJVJm
    I think the most likely origin of my problem is that I have some how configured something incorrectly, but I don't know what that could be. I copied the raw AdobeHDS.php file from github and placed it in the cdrive PHP folder.
