Page 7 of 12
FirstFirst ... 5 6 7 8 9 ... LastLast
Results 181 to 210 of 349
  1. Cool! I was using grabanymedia but with firefox+adbp it's faster.
    Anyway thank you
    Damn I feel a little silly, I've read over and over the code to be sure it was correct and everytime I was missing that "m"
  2. Hi guys
    I want to download a video from AkamaiHD, but I can't and always returns the same problem
    php AdobeHDS.php --quality high --delete --manifest 'http://bngn-vh.akamaihd.net/z/43383936/35470338/smil/CL/00007/263788578773609.smil/manifest.f4m?hdnea=st=1428756838~exp=1428757138~ac l=/*~hmac=9ad4185613f3ea318d8bce0bb85c8627ebe581092d9 45bb71388df06f1bc5b26&g=WKTOZIYQXRKW&hdcore=3.2.0'
    Access Denied! Unable to download the manifest.
    This is the link with the video
    http://www.daisuki.net/anime/watch/SaintSeiyaSoulofGold/IYc
    I read in others forums that I need get an new token because it expire very fast. How i can get it from curl? I'm using linux to do that.
    Please help
  3. Originally Posted by dragonx View Post
    Hi guys
    Please help
    HDS protocol is encrypt DRM protection you can use HLS protocol
    read this post
    https://forum.videohelp.com/threads/369812-How-to-Rip-From-Daisuki-net?p=2370928&viewfu...=1#post2370928
    Apr 2015
    torrance, ca
  5. Thanks!
    Do you know how download the subtitles from the same video?
    If I change the language I don't see other traffic different from video/f4f.
    I thought that subtitles comes with the video (like a mkv) but not.
  6. Originally Posted by dragonx View Post
    Thanks!
    http://bngnwww.b-ch.com/caption/35470338/1685/139335770465031/1459120739.xml
    you can find the url with adblock plus firefox addon too search for 'caption'
    you can open the file with notepad to delete all languages that does not interest you and convert with SubtitleEdit .ass format
  7. Thanks,
    I use a script in php to choose the language and other in xsh to create the .srt file
  8. Hi,
    With AdobeHDS i have downloaded the segments, but at the end the flv file was not created.
    Is there a possibility to join them?
    Help please.
  9. Hi waelse ,
    The best way is to try again with at the end --outfile My_video.flv
    php AdobeHDS.php --manifest "http://.../manifest.f4m?..." --delete --auth "..." --quality high --useragent "Mozilla/5.0 ..." --outfile My_video.flv
    more info: https://github.com/K-S-V/Scripts/wiki
    Come back and tell me if you have got the .flv file .
    ( if not I'll try to create an other help . Q: have you a spreadsheet ? )
    Cheers .
    JE SUIS CHARLIE !!!
  10. Originally Posted by aazerty View Post
    Hi waelse ,
    Cheers .
    Hi,
    unfortunately i dont have the manifest more. Is there a possibility to join the files without it?
    From the wiki:
    if you fragments are serially numbered without a base filename (1.f4f, 2.f4f.......99.f4f) then you can run the script without any parameter and it will look for the fragments in current directory and output will be saved as Joined.flv.
    However if your fragments are named with base filename (MyVideo-Seg1-Frag1.f4f, MyVideo-Seg1-Frag2.f4f.........MyVideo-Seg1-Frag99.f4f) then you can pass the base filename with fragments switch to the script and it will look for the fragments starting with this name and output will be saved as MyVideo-Seg1-Frag.flv. f4f extension is optional.
    php AdobeHDS.php
    php AdobeHDS.php --fragments MyVideo-Seg1-Frag
    or
    php AdobeHDS.php MyVideo-Seg1-Frag
    I dont understand exactly how to proceed. Shall my files be in the same folder as the adobeHds plug-in? Shall i write exactly the same command, or i must replace MyVideo... with the base name of my files?
    Other thing - to activate the adobeHds i must tape php c:\AdobeHDS.php and not only php AdobeHDS.php as indicated in the tutorials.
    Sorry for my bad english
  11. @ waelse
    can you post original link of the video
  12. It was a live stream, there are no more links to it.
  13. Originally Posted by waelse View Post
    pageUrl
  14. Hi waelse ,
    Cheers .
    JE SUIS CHARLIE !!!
  15. Member Emeritus
    May 2014
    Re-read the wiki.
  16. Originally Posted by aazerty View Post
    Hi waelse ,
    Cheers .
    What is a spreadsheet?
  17. Originally Posted by ponens View Post
    Re-read the wiki.
    if i paste in the command line php AdobeHDS.php MyVideo-Seg1-Frag (php c:\AdobeHDS.php MyVideo-Seg1-Frag), i got the message "Found 0 fragments"
  18. if you post the page with the link, it would be easier to help you
  19. It don't exist anymore
    It was at https://www.staatsoperlive.com/en/live/
    I payed for the stream and used the adobeHds to grab it. Sometimes i got the flv-s, sometimes no.
  20. Originally Posted by waelse View Post
    did you try hds-link-detector
    addon on firefox
  21. I used the hds-link-detector, downloading starts but at the end there was the message "Found 0 fragments". I have the segments (not sure if all), with consecutive numbers.
  22. Hi waelse ,
    A calculator : example Excel or Lotus_123 .
    'MyVideo-Seg1-Frag' : the syntax is wrong as yours is xxx-Seg1-Fragyyy
    And each xxx-Seg1-Fragyyy should be xxx-Seg1-Fragyyy.f4f
    That's the goal of my process !!!
    Cheers .
    JE SUIS CHARLIE !!!
  23. Originally Posted by aazerty View Post
    Hi waelse ,
    Cheers .
    Thank you for the hints.
    But where i must put the files, so AdobeHds can find them?
  24. Hi waelse ,
    Supposing php.exe and adobehds.php are in c:\php
    1) in "c:\php" create a batch file ( Upd.bat ) ( see below ) , for updating AdobeHDS.php
    @echo on
    php AdobeHDS.php --update
    pause
    :end
    2) Be sure all your fragments are numbered continuously . IMPORTANT !!!
    xxx-Seg1-Fragyyy.f4f => yyy = 238042296 <= THIS THE FIRST ONE ??? Yes/No ?
    3) in the folder , where are your fragments create and save a batch file "join.bat" , in it .
    @echo on
    "C:\PHP\php.exe" "C:\PHP\AdobeHDS.php" Seg1-Frag --start 238042296
    pause
    :end
    Launch it .
    === example of Process ===
    KSV Adobe HDS Downloader
    Found 1335 fragments
    Joined 1335 fragments in 44.46 seconds
    Finished
    Got a file "Seg1-Frag.flv" (1 205 872 ko)
    I am disturbed with fragments = 1ko (???) .
    Maybe you'll have issue while watching your video (?) .
    > Q: have you a spreadsheet ? Yes/No .
    Cheers .
    JE SUIS CHARLIE !!!
  25. Member Emeritus
    May 2014
    Nevermind...
  26. Originally Posted by aazerty View Post
    Hi waelse ,
    @echo on
    pause
    :end
    @echo on
    pause
    :end
    Launch it .
    Finished
    Cheers .
    Thank you very very much!
    It worked!!!
    My join.bat :
    @echo on
    "C:\PHP\php.exe" "C:\PHP\AdobeHDS.php" f763e03da2c7f32b097a5bca337d0490_4192_f0076eeb4b43 b18a-p_Seg1-Frag --start 238042296
    pause
    :end
    All my best wishes!
  27. Greetings. I was thinking of buying Bottle Rocket Babes (adult content) from this site http://www.hotmovies.com/video/30604/Bottle-Rocket-Babes/ (or a similar site) but was trying to figure out if I should until I figured out how to download the sample video. I've tried media stealer for Firefox and videocacheview. I seem to have no luck at figuring it out. Anyone want to try grabbing a preview vid and letting me know if it worked for you?
  28. Member Alex_ander's Avatar
    Oct 2006
    Russian Federation
    Does the AdobeHDS script join chunks properly in case the video is neither .flv nor .mp4? I came across a fragmented .ts streaming file I need to download. Can't find any manifest file (neither Firefox plugin helps) but the 173 chunks are downloadable and playable as .ts with avc video/audio. Is there positive experience of joining such fragments with that script?
    Thanks in advance.
  29. Originally Posted by Alex_ander View Post
    Thanks in advance.
    1) open cmd.exe (command shell)
    2) go in the folder where are all fragments .ts (example C:\videos)
    cd C:\videos
    3) join
    copy /b *.ts video.ts
    so you have the file video.ts in C:\videos
