Page 5 of 12
FirstFirst ... 3 4 5 6 7 ... LastLast
Results 121 to 150 of 349
  1. Hi ,
    @ggnobrega : This is for "flash" streams without "DRM" !!!
    ===== 1st stage ===
    Using Firefox , you'll have to install "HDS Link Detector" , known version 0.6 .
    ( https://addons.mozilla.org/fr/firefox/addon/hds-link-detector/ )
    _ restart FF .
    _ if an icone is not present over the task bar , do <Ctrl and /> simultaneously .
    _ click on that icone , and click to "Enabled" ( grey => red )
    ===== 2nd stage ===
    Enter the link for the page , to watch the video , on your computer .
    When your video will start , a small window will appear over the task bar .
    !!! be carefull , and put the mouse's cursor in this area !!!
    Click on it .
    Open a text editor , do "paste" .
    ===== 3rd stage ===
    Now , you'll get something , like at #118
    https://forum.videohelp.com/threads/342430-F4F-capturing-converting?p=2317702&viewfull=1#post2317702
    ===== 4th stage ===
    You can :
    _ make a batch file <= PREFERED see below
    _ or paste directly in a cmd window
    The informations given are not always ACCEPTED !!!
    You'll have to modify after .f4m , see example below :
    ( ?hdcore=2.11.3&g=GYXKOKXQAXHS , instructions are given in the auth )
    --manifest "http://... .mp4.csmil/manifest.f4m?hdcore=2.11.3&g=GYXKOKXQAXHS"
    --delete --auth "als=0,0.1,0,3,0,NaN,0,0,0,31,f,0,5586.24,f,u,GYXKOKXQAXHS,2.11.3,31&hdcore=2.11.3"
    ====== batch file !!! EXAMPLE !!!
    @echo on
    php AdobeHDS.php --manifest " ..... =2.11.3"
    pause
    :end
    ===== 5th stage ===
    Launch your batch file , if it's ok , you'll get something like this :
    KSV Adobe HDS Downloader
    Processing manifest info....
    Quality Selection:
    Available: 1235 699 369 187
    Selected : 1235
    Fragments Total: 931, First: 1, Start: 1, Parallel: 8
    Downloading 29/931 fragments
    Regards .
    Apr 2014
    Brasil
    Originally Posted by aazerty View Post
    Hi ,
    ===== 1st stage ===
    _ restart FF .
    ===== 2nd stage ===
    Click on it .
    ===== 3rd stage ===
    ===== 4th stage ===
    You can :
    @echo on
    pause
    :end
    ===== 5th stage ===
    Quality Selection:
    Selected : 1235
    Regards .
    How do I know they use DRM?
    The auth parameter is used for what?
    regards
  3. Hi ,
    @ggnobrega :
    1) usually http.../manisfest.f4m is without DRM
    2) Example http... episode-1.f4m is with DRM
    3) "HDS Link Detector" will be unable to create the "php AdobeHDS.php --manifest ..."
    1) as a cookie
    2) geolocalisation
    3) etc ...
    Regards .
    Apr 2014
    Brasil
    Hi ,
    @ggnobrega :
    1) as a cookie
    2) geolocalisation
    3) etc ...
    Regards .
    I understood, but the error i get is "access denied" not "unable to create..."
    and the file name is manifest.f4m? so I Think its not DRM
  5. Hi ,
    @ggnobrega :
    === I have read ===
    Access Denied! Unable to download manifest.
    You have to read , again , the stage 4 . On how to create "http ... /manisfest.f4m? ..." .
    Maybe the problem is here (???) .
    Give us the link for the video , you need ; for try .
    Regards .
    Apr 2014
    Brasil
    Originally Posted by GrabAnyMedia View Post
    Watch this video, very simple
    https://www.youtube.com/watch?v=97kIwrYSc0g
    Thanks a lot bro
    I tried with other links and it was all right, but with the one I need i get the error
    Access Denied
  7. Originally Posted by ggnobrega View Post
    Thanks a lot bro
    Access Denied
    Bro , post your link i want check this problem
    Dec 2009
    Cyprus
    Originally Posted by BobTheDeveloper View Post
    Originally Posted by neroman00 View Post
    Can you help me how to download an encrypted video
    I am using HiDownload Platinum, version 8.23 but the program cannot download this video: http://www.megatv.com/megagegonota/summary.asp?catid=27377&subid=2&pubid=33249597
    The video file name is: manifest[1].f4m
    THANKS
    http://www33.zippyshare.com/v/38559683/file.html
    Thanks a lot but how you did it? what is the trick?
    You can follow this infographic.
    Tool: StreamTransport V1.1.2.0
    It requires to run on Windows 7 or lower with IE 10 or lower.
    https://fbcdn-sphotos-d-a.akamaihd.net/hphotos-ak-ash3/t1.0-9/1969128_762764837090317_...51237409_n.png
    Thanks mate! I am using StreamTransport version 1.1.3.0
    I am also using Firefox 30 (if this matters) and as per your guidelines, there is nothing to choose and download at the bar below. For instance, I tried this: http://www.livenews.com.cy/cgibin/hweb?-A=40471&-V=megatvvod
    Please advice
  9. Hi ,
    @neroman00 :
    http://media.livenews.com.cy/DesktopModules/IST.MediaServices/LiveMediaPlayer.aspx?itemid=33461&autostart=1
    Read this , maybe it will help you (?) .
    https://forum.videohelp.com/threads/356428-How-to-record-or-capture-silverlight-ism-manifest-stream?p=2317938&viewfull=1#post2317938
    Cheers .
  10. All of you who claim that F4F files are just split F4V files, that each can be played independently, you are wrong! They are missing a key element of a normal playable F4V file. The F4V file specification indicates that the file is divided into "boxes", each can contain data as well as other "boxes" in a hierarchical structure, in much the same way as RIFF files are divided into "chunks".
    The most important box in an F4V file is the movie box (containing the 4character string MOVI in the actual F4V file), as it has important specifications for the video file like duration, frame-width, and frame-height. F4F files have this MOVI box stripped from the file, so it is unplayable. This data is stored in a separate file with the extension F4M, and usually has the filename "manifest.f4m". As a result, it is impossible to just combine F4F files into a single playable F4V file, without the converter software reading required data from the associated F4M file.
    Has ANY HACKER OUT THERE yet created a converter which is capable of doing this? This is becoming the NEW STANDARD of streaming video on the net, as even without encryption, no current video player or converter is capable of playing or converting these files. The demand is high for players and converters that can work with these files. But so far as I've seen, there's not been any hacker to create such. Despite the demand for such software, the demand has gone unanswered!
    Apr 2008
    Canada
    any solution for DRM protection..? pls help..Thanks
  12. Microsoft Windows [Version 6.1.7600]
    Copyright (c) 2009 Microsoft Corporation. All rights reserved.
    C:\Users\3ed>cd php
    The system cannot find the path specified.
    C:\Users\3ed>cd .. php
    C:\Users\3ed>cd ..php
    C:\Users\3ed>cd php
    C:\Users\3ed>cd..
    C:\Users>cd..
    C:\>cd php
    C:\PHP>php AdobeHDS.php --manifest "http://beinsportnet3-lh.akamaihd.net/z/bisus
    ch307_0@99699/manifest.f4m?hdnea=st=1409953468~exp=1409953528~ac l=/*~hmac=677357
    10c526d0ba2eb02b489ddf1e6c5329ab91fa686b40a34648b9 d420f72c&g=BNBHRNXWNXJV&hdcore
    =3.4.0&plugin=aasp-3.4.0.132.124" --delete --auth "hdntl=exp=1410039899~acl=%2f*
    ~data=hdntl~hmac=18f41948873dc016cfde3b45610002d3a f6670e5f488c3cd9de1ff749e67ea1
    8&als=0,3,NaN,1,0,NaN,0,0,0,41,f,0,5952,t,s,BNBHRN XWNXJV,3.4.0,41&hdcore=3.4.0&p
    lugin=aasp-3.4.0.132.124" --useragent "Mozilla/5.0 (Windows NT 6.1; WOW64; rv:31
    .0) Gecko/20100101 Firefox/31.0"
    C:\PHP>php AdobeHDS.php --manifest "http://beinsportnet2-lh.akamaihd.net/z/bisus
    ch305_0@99697/manifest.f4m?hdnea=st=1409953633~exp=1409953693~ac l=/*~hmac=9df6d5
    4b166f4602051bc7d314afac77aec6333a8ee9ff74049b87c6 1fae044a&g=WWUXTBCDXZIT&hdcore
    =3.4.0&plugin=aasp-3.4.0.132.124" --delete --auth "hdntl=exp=1410040064~acl=%2f*
    ~data=hdntl~hmac=0f226da1714cb6ec20cba56335ba429de 640b035a5f7f93535da8978016328a
    6&als=0,3,NaN,1,0,NaN,0,0,0,35,f,0,5952,t,s,WWUXTB CDXZIT,3.4.0,35&hdcore=3.4.0&p
    Quality Selection:
    Available: 2400 1500 1000 512 280
    Selected : 2400
    Updating bootstrap info, Retries: 1
  13. need help
    PHP Code:
    C
    ch307_0@99699/manifest.f4m?hdnea=st=1409953468~exp=1409953528~acl=/*~hmac=677357
    10c526d0ba2eb02b489ddf1e6c5329ab91fa686b40a34648b9d420f72c&g=BNBHRNXWNXJV&hdcore
    ~data=hdntl~hmac=18f41948873dc016cfde3b45610002d3af6670e5f488c3cd9de1ff749e67ea1
    8&als=0,3,NaN,1,0,NaN,0,0,0,41,f,0,5952,t,s,BNBHRNXWNXJV,3.4.0,41&hdcore=3.4.0&p
    Access DeniedUnable to download manifest.
    ch305_0@99697/manifest.f4m?hdnea=st=1409953633~exp=1409953693~acl=/*~hmac=9df6d5
    4b166f4602051bc7d314afac77aec6333a8ee9ff74049b87c61fae044a&g=WWUXTBCDXZIT&hdcore
    ~data=hdntl~hmac=0f226da1714cb6ec20cba56335ba429de640b035a5f7f93535da8978016328a
    6&als=0,3,NaN,1,0,NaN,0,0,0,35,f,0,5952,t,s,WWUXTBCDXZIT,3.4.0,35&hdcore=3.4.0&p
    Quality Selection:
    Available2400 1500 1000 512 280
     Selected
    2400
    Retries
  14. Hi ahmed3ed ,
    Give us the link to the video .
    Cheers .
  15. Originally Posted by aazerty View Post
    Hi ahmed3ed ,
    Cheers .
    this video url
    http://www.ar.beinsports.net/connect
    but u need arab proxy
    212.118.123.37 port 443
    thank you for interesting
  16. Hey bro i have developed a little GUI tool in java cross platform for AdobeHDS.php, tested on Windows/Linux/Mac
    Tutorial and Download
    If you want more options please comment main post on download page, hope this help some guy
  17. How about create a standard EXE file, rather than depending on PHP. I already have downloaded the manifest (F4M file) for a video I'm interested in. I have already downloaded the video segments (F4F files). I need an executable program written in any language (VB, C++, Java, etc) that simply reads the F4M file to determine the things it needs to determine, then reads the F4F files, and assembles from these files a proper F4V standalone video file that will be playable in VLC player. Your PHP script is used to download and compbine files. I do not need "download and combine". I just need "combine" which is something that a standalone EXE file should be able to accomplish quite nicely. So I am requesting that you create for me, a regular executable program that will allow me to combine the manifest and video segments that I have already downloaded into a proper F4V video file.
  18. Hi ,
    The commands-line "php AdobeHDS.php ..." without --delete , don't destroy 'segments files' .
    Cheers .
  19. Deceased
    Dec 2007
    That is incorrect. The f4m manifest is not required to process/join f4f segment(s). The adobehds.php can process a single (or join multiple) f4f segment(s) without any manifest, so long as the segments don't have any drm and are sequenced in order. See the adobehds.php wiki pertaining to offline fragment processing. If that doesn't convince you, see an example from this very thread of a single f4f segment before and after processing with the adobehds.php script (posts #111 and #112 in this thread). Fragments can be joined offline without downloading and without a manifest, assuming proper sequencing and the lack of drm. But if a fragment does have drm, the script will indicate so.
    The adobehds.php script does combine without downloading (see the wiki link referenced above). If you don't want to install php, there is a standalone executable version hdsdump.
  20. hello, i see all page too hard =S ... i need more 149 videos ahahhaha... nvm is a tutorial too much work.
    i found application can download f4f to mp4 or other... call "Hulu Downloader v2.7.1.8"
    Problem is trial just 10 minutes =( ... i need crack or patcher, who can help me?
    Web Official:
    http://www.hulu-downloader.com
    Download Mirror:
    https://mega.co.nz/#!uQ93SSaA!9LZDfN2wKzw2ZyBRVPAy97sXsiLCQJQRE_oGqV9nv44
  21. I'm a MEGA Super Moderator Baldrick's Avatar
    KingRider: Please reread our rules about warez, https://forum.videohelp.com/threads/72386-Forum-rules-Acceptable-Use-Policy-(AUP)?
    BUY it or find a free software.
  22. Oh!! Sorry.. its ok
    I try all application from videohelp is not work to me =( .. problem akamaihd is protected are exist 4 key auth, frag, cache and session too hard.
    Grabanymedia is not work me.
    Screenshot:
  24. yes i know, getflv... problem protocol different is work to me a download akamaihd
    happen huludownload is available 64bits no need win xp... its getflv need 32 bits with win xp
    how which can?
    i try getflv to properties compatibility win-xp is take download just close and crash. my windows last version 8.1 original =/
    Last edited by KingRider; 25th Sep 2014 at 21:24. Reason: more situation a word.. sry bad english
  25. can someone help with this link
    PHP Code:
    http://cf.c.ooyala.com/5wcmRmcjqckqtQQ_aMm8xu5NsMo-Q8rU/BUc12Zw0Vb8eXvffnz6WqqK9zTtMPN2OzV_3MMkJaNYaZy8G6bjQBJ_fnbg9Ws5J/video_300_320Seg1-Frag1
    it has 53 fragments
    i download php and i download AdobeHDS.php and i did all the steps and when i post the code in CMD it Says
    Ksv Adobe HDS Downloader
    Unable to download the manifest
  26. Originally Posted by mrwolf View Post
    PHP Code:
    it has 53 fragments
    hello
    can you post the original link
    thank
  27. Code:
    php AdobeHDS.php --manifest "http://cf.c.ooyala.com/5wcmRmcjqckqtQQ_aMm8xu5NsMo-Q8rU/5wcmRmcjqckqtQQ_aMm8xu5NsMo-Q8rU_1.f4m" --delete
  28. Originally Posted by KingRider View Post
    Web Official:
    Download Mirror:
    https://www.mywot.com/en/scorecard/vdigger.com
