Page 10 of 12
FirstFirst ... 8 9 10 11 12 LastLast
Results 271 to 300 of 349
  1. Originally Posted by xingxingjiang View Post
    Thanks for your reply.
    I have tried HDS Link Detector, but it still get the same error:
    "C:\>php AdobeHDS.php --manifest "http://ak.c.ooyala.com/Yxa2djczpsSkxBnCYgjIJVJm
    Oo3ZTf8Y/Yxa2djczpsSkxBnCYgjIJVJmOo3ZTf8Y_1.f4m" --delete --outfile somefile.flv
    Could not open input file: AdobeHDS.php"
    I think the most likely origin of my problem is that I have some how configured something incorrectly, but I don't know what that could be. I copied the raw AdobeHDS.php file from github and placed it in the cdrive PHP folder.
    hi
    but did you run the code in the PHP and AdobeHDS.php 's folder
    example if you have AdobeHDS.php in C:\PHP
    run command prompt
    and go in C:\PHP with this command
    cd C:\PHP
    and paste your code
  2. Thanks for the suggestion.
    I tried running it in a command prompt opened in the folder and got back this result:
    C:\PHP>php AdobeHDS.php --manifest "http://ak.c.ooyala.com/Yxa2djczpsSkxBnCYgjIJ
    VJmOo3ZTf8Y/Yxa2djczpsSkxBnCYgjIJVJmOo3ZTf8Y_1.f4m" --delete --outfile somefile.
    flv
    C:\PHP>
  3. Originally Posted by xingxingjiang View Post
    flv
    C:\PHP>
    maybe you copy the raw and paste in notepad and save in bad extension (.txt for example)
    try this and save in C:\PHP
  4. Bingo! Yeah, I had a php with a txt extension. Actually, I had a correct php extension before, but I hadn't had the correct folder. Thanks guys!
  5. Hi Guys. We are running Windows on X64 OS
    We have downloaded and installed AdobeHDS and php from the following websites:
    https://github.com/K-S-V/Scripts/blob/master/AdobeHDS.php
    http://windows.php.net/download#php-5.6
    VC11 x86 Thread Safe (2015-Sep-04 02:29:46)
    http://windows.php.net/downloads/releases/php-5.6.13-Win32-VC11-x86.zip
    The bat file has been set up with the manifest correctly coded.
    However when we run the bat file we get:
    KSV Adobe HDS Downloader
    You have to download and install the following extension(s) to continue: 'curl'
    However the "php_curl.dll" file is in the "ext" folder.
    Many thanks - SB
  6. Aha - we needed the php.ini file to be configured!!!
  7. Video Download Helper extension for firefox. Select the downloads that just say "Media" or "F4F streaming FLV", not the downloads that say mp4 or give a file size in brackets.
    Internet Download Manager will also download that video but you will have to rename the file it downloads to .mp4
    Or you can use KSV Adobe HDS Downloader with the code:
    php AdobeHDS.php --manifest "http://27.102.199.60:1935/vod/_definst_/sexymobil/data/fcastle/model2/model174/movie/movies/20110815_movie.mp4/manifest.f4m" --delete
  8. Hello!
    I'm having this problem of "Access Denied! Unable to download fargments" when I'm trying to download a video.
    I believe that my manifest is correct, I use HDS Link Detector to get him and I confirm it with the Firefox Console. I can watch it in the browser, it is in the middle of the page, if you want to see here is the link: https://www.cers.com.br/cursos/isoladas-9/semana-do-direito-do-trabalho/curso-de-lingu...aria-augustarj
    Someone can help me to find the solution please?
    Tks
  9. I just dowloaded it fine using:
    php AdobeHDS.php --manifest "http://cers11hds-vh.akamaihd.net/z/account/869/1/2015-05-27/video/,4cba707ae513a5f2d5411a4c21fe9d71/RJ_052715_500_QUEST_FCC_L_PORT_AULA_01_PT_I_240p,c25be3781ca5aa6a748b41782c0c57bd/RJ_052715_500_QUEST_FCC_L_PORT_AULA_01_PT_I_360p,0a2b3ddd7f9d7f52f1b13ac1530975d3/RJ_052715_500_QUEST_FCC_L_PORT_AULA_01_PT_I_480p,a9cc8760b9f9e52e6a9f4130b49b5550/RJ_052715_500_QUEST_FCC_L_PORT_AULA_01_PT_I_720p,.mp4.csmil/manifest.f4m?hdnts=st=1443462436~exp=1443463516~acl=/*~hmac=e0b0648225ee5633511991414a0e7fc446a86086737b651e1a99b0668add62c5&g=ISPDEMTTCOPB&hdcore=3.4.0&plugin=flowplayer-3.4.0.0" --delete --auth "pvtoken=exp%3D9999999999%7Eacl%3D%252f%252a%7Edata%3DZXhwPTE0NDM1NDg2MDd+YWNsPSUyZip+ZGF0YT1wdmMsc35obWFjPTUzMmVmNGVjYWNjNDMyNWJlYTcxNjcxZjZhYzI4NTFkNGRhOTIxYzk5ZGVhYTZlYjQ4YjQ1MmZlN2RjYmFjNTc%3D%21ME5f22/D9clKa5P8dvDBa9xvFN0I0YsFSWuwKk2oeMw%3D%7Ehmac%3D4F109A61E40CFDA483FDCD054E63C6A46BFB071D35089F0503DEF20ABFDCC110&als=64.01,60,2400.67,2,205,254403,13.74,1765,0,56,f,210.48,1920.04,f,s,VLUBJKMQKCDG,3.4.0,56&hdcore=3.4.0&plugin=flowplayer-3.4.0.0" --useragent "Mozilla/5.0 (Windows NT 6.3; rv:40.0) Gecko/20100101 Firefox/40.0"
    Video Download Helper extension for firefox also worked, as did Internet Download Manager
  10. OMG it realy works , how did you got that path? I use HDS Link Detector, but looks like my path have something wrong.
    Now Video Downloader Helper works to... I dont understand, I try several times this addon.
  11. Originally Posted by Kcastle View Post
    Can anyone tell me how to download this video?
    http://web.f-castle.com/media/view_popup.php?cate1=1210
    The clips are seg frag
  12. Kcastle, the answer I gave above works, did you try it?
  13. The clips can't be played how can i join them
  14. Originally Posted by Moet View Post
    The clips cannot be played independently how to join them
  15. KSV Adobe HDS Downloader will join the fragments automatically once it has downloaded them all.
  16. Hi Kcastle ,
    php AdobeHDS.php --manifest "http://27.102.199.60:1935/vod/_definst_/sexymobil/data/fcastle/model2/model174/movie/movies/20110815_movie.mp4/manifest.f4m" --delete --outfile 20110815_movie.flv
    Processing manifest info....
    Quality Selection:
    Available: 1295
    Selected : 1295
    Fragments Total: 118, First: 1, Start: 1, Parallel: 8
    Downloading 18/118 fragments
    At the end you'll get a file '20110815_movie.flv' .
    Cheers .
    JE SUIS CHARLIE !!!
  17. Hey guys, Im on my wits' end here...
    Been trying to download the video from here http://www.elmundo.es/tendencias/2014/10/17/543fb4e6ca4741fd4c8b4581.html to use inside our company, it is my actual boss giving the interview so I guess we should be able to own it, even though the medium isn't giving us the video.
    I have tried everything, from AdobeHDSHelper to Grab Any Media and HDS Link detector.
    Can you guys give me a hand?
    This is the link to the video:
    http://k.uecdn.es/index.php/kwidget/wid/_108/uiconf_id/8704917/entry_id/0_jj9p8tqq
    PLEASE HELP!!!
  18. Oh! I run a MacOS and am a newbie so couldn't run the KSV script, if you guys can lend me ahand and teach how to run scripts and which url i have to use, i get three .f4m urls:
    http://k.uecdn.es/p/108/sp/10800/playManifest/entryId/0_jj9p8tqq/format/hdnetworkmanif...Q1ODEuaHRtbA== [HTTP/1.1 200 OK 25ms]
    http://uemundoor-vh.akamaihd.net/z/content/108/2014/10/16/0_jj9p8tqq/0_jj9p8tqq_0_,mm4...p-3.5.0.151.81 [HTTP/1.1 200 OK 40ms]
    http://universal-vh.elmundo.es/z/content/108/2014/10/16/0_jj9p8tqq/0_jj9p8tqq_0_,mm40v...p-3.5.0.151.81 [HTTP/1.1 200 OK 53ms]
  19. lord4ghost : Hello Brother
    this link its esay i will download before with IDM download Manager.. this link file video "ts" then u can convert Mp4
    But,,
    We need video Shahid Plus I Try But I don't can't down
    is it anyone to Help Me for that ?
    this link
    http://l3hdsmedia.shahid.net/media/0e06f31007d14152bb9e252a85db4fa5/f5a02e3ba36c4a48ac...00-Seg1-Frag50
    http://l3md.shahid.net/hds/mediaDelivery/media/f5a02e3ba36c4a48ac5b259118a435d1.f4m?cdn=l3
    http://l3hdsmedia.shahid.net/media/0e06f31007d14152bb9e252a85db4fa5/f5a02e3ba36c4a48ac...eng%3D2496000-
    I extract link zoom display see that :
    http://assets.delvenetworks.com/player/fp10loader.swf?allowEmbed=true&allowSharePanel=...e3dccd6395dfbe
    How i can download this ?
    thanks all..
  20. I'm running into this error when running the script.
    You have to install and enable the following extension(s) to continue: 'curl'
    How do I install extensions for PHP? And equally importantly, where do I download such extensions? Is there a site with an archive of extensions for the PHP software somewhere?
  21. Originally Posted by Videogamer555 View Post
    hi
    normally the extensions are already in the ext/ folder in your PHP folder
    you can activate them if you create a PHP.ini file in PHP folder
    here already PHP.ini created by KSV (at the end of the page)
    https://github.com/K-S-V/Scripts/wiki
  22. Member
    Oct 2015
    Croatia
    I tried some of the suggestions and it didn't work for me. Probably because I'm bad at this stuff, but can anyone check it out:
    http://www.ehftv.com/de/video/150614-ehf-iceland-montenegro
    I have problems with laola tv for almost two years, I could never download or capture screen from that site. Can anyone help with this?
  23. Not sure if you are taking requests now, but I would like to request that your F4F combiner output a proper F4V file instead of an FLV file. The F4V file is based on the MP4 file structure, while the FLV file has its own structure. And since F4F files are simply split F4V files (not split FLV files), it is more proper to combine F4F segments into an F4V file, rather than constructing an FLV file structure and putting the data from the F4F files into this new structure. Unfortunately your current script does exactly what it shouldn't, and creates an FLV file rather than an F4V file. I strongly suggest changing this, so that your script behaves in a more proper way. There may be some source videos who's F4F segments/fragments won't work if put into an FLV file, because they may depend on the data that can only be held in an F4V structure.
  24. [QUOTE=Chug a Bug;2199352]
    Originally Posted by andrewcrawford View Post
    In other news I've uploaded a standalone Adobe HDS downloader (no need to download and install PHP etc) you can find it here:
    http://www.sendspace.com/file/pmo7hu
    I noticed that Chrome thinks the file is malicious. Might this be because it contains a *.bat file, or is there room for concern?
  25. Hello
    how can I download Video from
    http://www.n24.de/n24/Mediathek/Dokumentationen/d/7577140/24-stunden-an-den-brennpunkt...ingskrise.html
    i installe Adblock Plus but do not get Manifest Link.
  26. Originally Posted by Videopaul View Post
    Hello
    hi
    not hds protocol (f4m) but hls protocol (m3u8) so search m3u8 with adblock plus addon
    livestreamer "hlsvariant://http://n24video-vod.dcp.adaptive.level3.net/cm2013/...............mp4.m3u8?tlm=hls&streams=............................" best -o video.ts
    nota: a thought for all migrants welcome in Europe or where you want/can
  27. Member Emeritus
    May 2014
    Hello
    There is http progressive url in the source of the webpage.
