Hi again,
After the prompt help in the other forum, i have another (unrelated) question -
I'm using AutoGK to convert a live show video with DTS sound.
I'd like to preserve the DTS soundtrack (pass-through), but when i try to convert it to Xvid using AutoGK, i keep getting the following error:
EXCEPTION: Audio is not found
I tried ripping without stream processing, so that the stream has two soundtracks - AC3 and DTS. If i only select AC3, it works fine.
If i select DTS or both, i get the Audio is not found error.
I tried searching the forums for help, but all i could find are transcoding issues (which require decoders, that i have also tried to install, just in case).
I tried several sources of videos with DTS - no luck.
Any suggestions?
Perhaps another tool that can convert the DTS-containing VOB to AVI?
Thanks in advance!
Results 1 to 15 of 15
Replace the AC3 with the DTS in the completed AVI?
Do the conversion manually and avoid AutoGK completely?
However, according to Q. 2.9 of the AutoGK FAQ, AutoGK can use the DTS audio:
http://forum.doom9.org/showthread.php?t=72679 -
Thanks for your replies.
Manono - I'm trying to remove the AC3 and keep the DTS as is (no re-encoding, just pass-through)
Sambat - I know AviMux can re-mux. But this would mean that i demux while ripping, encode the video alone, and re-mux with the DTS afterwards.
I know it doesn't sound that bad, but i'm not trying to convert a movie but rather a music DVD, and i'm dividing it by chapter, for each song.
Some of them contain over 20 files, so i'm trying to keep the flow simple
Thanks! -
I'm guessing you're using the latest version, maybe there's a bug. Just to be sure these are the steps to follow to get an AVI with DTS audio:
- Select the IFO file as the source and set your destination folder
- Select the DTS audio in Step 2 audio box
- Set the output size in Step 3
- Click the advanced settings button in Step 4 and set the output audio type to Original
- Add job and start encoding
Check the log, if you get EXCEPTION: Audio is not found again; there's a good chance your DVD ripper stripped the DTS track, but didn't remove all the references to it. Make sure you select the DTS track when ripping. You can use Mediainfo to analyse the IFO and VOB.
If the log is clear and you still have no audio, use Mediainfo to check the AVI for audio. You need a CODEC to play DTS audio with any software player, refer to the Doom9 guide. Most hardware media player can't handle DTS in an AVI. Only thing left to do is try an older AutoGK version, if that works, you've found a bug in 2.55. -
Thanks guys, this gives me a new direction to test.
I'm using DVD Decrypter, and i'm splitting the chapters to VOBs (i don't use IFO's).
I'll try it with an IFO now, and if it still fails i'll try an older version of AutoGK.
If that fails too i'll revert to using video only VOBs with AutoGK and later on mux with the DTS using AVIMUXGUI with a batch file i'll have to make.
I'll report back, of course!
Thanks again! -
Thanks everyone, and kudos to nic2k4 - loading an IFO indeed does work.
But it doesn't solve my problem - i divide the DVD into chapters and have one VOB per chapter.
Is there a way to create one IFO per chapter?
Currently it seems as one per title...
If i try to do the procedure manually (Video only through AutoGK, then mux DTS+AVI using AVIMUX) i encounter delays which are not sourced from the DVD (not the audio delay which is specified in the filename).
Any idea on either of the issues?
Thanks again! -
Are you also saying that IFO somehow screws up the encode, maybe by giving you back an out-of-synch AVI?
When converting TV series to AVI I use DVDShrink (Nero Recode) (use the remake a DVD function) to split the episodes into separate titles, then run each title in AutoGK. You can do the same to convert individual chapters. Maybe you could use IFOedit to generate IFOs from the VOBs you get when ripping.
Thanks again for your support guys!
manono - no, the out of sync AVI is when i pass only the video through AutoGK and remux the original audio with the resulting AVI using AVIMUXGUI. I abandoned that path.
nic2k4 - i'll give it a shot.
Currently what i'm doing is to take the IFO and duplicate it so that there's one IFO for each chapter VOB.
I then rename the IFO files to be is if they were different titles and rename the VOBs as if they were the first chapter in each title.
I can also use the automatic dispatcher to load all IFO files to AutoGK.
Works like a charm
I'll try to create a batch file that does all the renaming automatically. -
Still struggling with the issue (not continuously though, obviously).
I had a revelation today. The "audio not found" exception is because i'm using the VOBs as inputs to the AutoGK.
Instead, i have to introduce the IFO file to the AutoGK. Then it work.
BUT - the IFO file is good for the entire DVD, and i need to split by chapter.
Is there any way to generate an IFO file per chapter?
Thanks in advance... -
You could use DVDShrink's re-author function, but an ifo per chapter.... there shouldn't be any need.Is there any way to generate an IFO file per chapter?
Anyway.... if you re-author with DVDShrink you can drag a title from the right pane to the left pane multiple times (in re-author mode), then use the edit function to edit each copy of the title down to a single chapter. After you use the back up function, you should end up with a single ifo and set of vob files for each of the original chapters. Just make sure to set DVDShrinks target output size to something large (or disable the compression) to it won't try to shrink while backing up.
How i can convert the dts-es or dts-ex 6.1 into dts core 5.1
By fits79 in forum Newbie / General discussionsReplies: 18Last Post: 19th Aug 2012, 16:25 -
How to passthrough 2 channel DTS and AC3 files?
By Phat J in forum AudioReplies: 4Last Post: 10th Jan 2012, 13:45 -
passthrough dts and ac3, reciever
By maxone71 in forum Software PlayingReplies: 1Last Post: 17th Oct 2011, 15:45 -
DTS problem with AutoGK
By extrabyte in forum AudioReplies: 0Last Post: 10th Jan 2009, 13:43 -
encoding with DTS audio stream - Audio not found in AutoGK
By extrabyte in forum DVD RippingReplies: 1Last Post: 7th Jan 2009, 16:42
