My Multiavchd project, where I used Multiavchd to put together all my 1920x1080 60P m2ts video files came out about 85% OK, but being the anal person that I am, I notice some choppiness with the audio, and some (but less) choppiness with the video. It is tolerable to watch but not as perfect as when I hook up my computer via a HDMI cable to my HDTV and play these same m2ts files.
Here is the facts.
I am playing the bluray disc on my PS3 blu-ray player.
I used imgburn to burn the video to a bluray disc.
Here is the mediainfo on my video files:
General
Complete name : C:\Users\Daddy's HP Laptop\Videos\10-24-2011\10-24-2011_084835.m2ts
Format : BDAV
Format/Info : Blu-ray Video
File size : 483 MiB
Duration : 2mn 33s
Overall bit rate : 26.4 Mbps
Maximum Overall bit rate : 28.0 Mbps
Video
Menu ID : 1 (0x1)
Format : AVC
Format profile : High@L4.2
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Format settings, GOP : M=3, N=30
Codec ID : 27
Duration : 2mn 33s
Bit rate mode : Variable
Bit rate : 25.1 Mbps
Maximum bit rate : 26.0 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 59.940 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.202
Stream size : 459 MiB (95%)
Audio
Menu ID : 1 (0x1)
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : 129
Duration : 2mn 33s
Bit rate mode : Constant
Bit rate : 256 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Compression mode : Lossy
Delay relative to video : -34ms
Stream size : 4.67 MiB (1%)
Text
Menu ID : 1 (0x1)
Format : PGS
Codec ID : 144
Duration : 2mn 32s
Is there a setting that I should change on Multiavchd? I am just using the default settings. For example, should I change from 1 pass Insane to 2 pass HQ using the fit all option? (seeing how i have 140 files). The thing is, doing this seems to automatically change the bitrate (lowers it). Is it supposed to do this? I want the same quality video as the source.
I like the fact that Multiavchd is so fast (compared to corel videostudio pro, which kept causing my PC to overheat and kept turning off + took forever). It is also way faster than Imtoo bluray creator 2 (which was SUPER slow).
Results 1 to 1 of 1
Dvd to Blu-ray multiAVCHD
By Marco33 in forum Authoring (Blu-ray)Replies: 5Last Post: 26th Jan 2012, 12:34 -
MultiAVCHD Blu Ray playing order problem
By 557953 in forum Authoring (Blu-ray)Replies: 0Last Post: 4th Dec 2011, 08:28 -
Multiavchd..Need Help..MKV-BLU RAY-- Freezing on Blu Ray Menu!!
By Thuglas in forum Authoring (Blu-ray)Replies: 1Last Post: 14th Sep 2010, 23:58 -
How to convert DVD project to Blu-Ray project??
By zentsang in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Jul 2010, 18:08 -
Multiple blu ray titles-No menu with AVCHDcoder or MultiAVCHD?
By thegeeman in forum Authoring (Blu-ray)Replies: 6Last Post: 22nd Sep 2009, 09:22
