just downloaded SimplyBurns (a basic and simple burn-ware) from sourceforge.net
downloaded file was expected to be .dmg, but actually it is .zip
did any anyone here successfully try it?
while compiling from source, i could not resolve dependancies may be its java.
thanks!
Assuming you're doing this on a Mac, just unzip the .zip file (Finder will do this for you after you double-click on it), and move the .app file inside to your Applications folder. From there, you can execute it whenever you want.
I have it on my Mac, along with another burning program, but haven't actually gotten around to burning any discs yet with it.If cameras add ten pounds, why would people want to eat them? -
that's what i tried, but could not locate executable, seems to me like raw source.Assuming you're doing this on a Mac, just unzip the .zip file (Finder will do this for you after you double-click on it), and move the .app file inside to your Applications folder. From there, you can execute it whenever you want.
anyway i just need to compare features against Disc Burner or DiscBlaze, but later on dropped the idea of trying new-wares!!!!
thanks for response!Last edited by Bonie81; 7th Jan 2012 at 16:18.
How are you opening it (the .zip archive)? The version I downloaded (and archived) is the same one shown in your picture - SimplyBurns-build-rev428.zip. It only contains one file, SimplyBurns.app.
Are you trying to open it on a non-Mac setup?
(Note that an .app is actually a set of folders with binaries and other files within, which the Mac will treat as a single executable package. Windows and Linux systems will tend to see it more as the set of folders and files it is.)Last edited by Ai Haibara; 7th Jan 2012 at 18:34.
Need basic info on Simple profiles when capturing video with XviD codec
By snafubaby in forum Capturing and VCRReplies: 1Last Post: 19th Mar 2011, 21:54 -
very basic question: can I burn a DVD from video_rm & video_ts files?
By glitterla in forum MacReplies: 3Last Post: 25th Feb 2010, 12:09 -
Simple Xvid vid will not burn, why?
By capman21 in forum Newbie / General discussionsReplies: 10Last Post: 9th Aug 2008, 20:44 -
Cannot burn a simple DVD
By hygieneboy in forum Authoring (DVD)Replies: 14Last Post: 14th Jan 2008, 11:45 -
A basic, simple video editing program?
By Salva Veritate in forum Newbie / General discussionsReplies: 5Last Post: 25th Jul 2007, 14:50
