Hi
Looking for some(alot) help, on how to add s second language subtitle to a Homemade DVD movie.
I have tried the guides posted by: TheMatrixx/Paddington/bluedha. no luck.
These guides mention having a pre existing subtile file.
I'm starting from scratch, the dvd doesn't have any type of subtitle file.
Thx!!! in advance
terra
Use the other subtitle as source(extract it with subrip) and start translating it. I think subtitle edit has a built in translator with help of google translate.
Or extract the main movie from the dvd with vob2mpg and use it in subtitle edit or subtitle workshop and type the subs.
Then follow https://forum.videohelp.com/threads/277950-How-to-add-new-subtitles-to-an-existing-DVD -
Hi Here are the steps I took 1) used SubRip to pull out the subs. saved the file with default names. 2) used Subtitle Edit to open the saved file from above. i then translate the file to the language(chinese), fix common errors. then save the file under a different name. 3) i then use subtitle creator to save the file as sup format. 4)launch the dvd authoring tool. setup all the parameters(pgcdemux/muxman/vobblanker). Also the output folder. I then select the sup file I saved earlier, and the appropriate language(chinese). 5) sit and wait. Receive the ok msg. 6) then i play thru smplayer. it seems to work, can you suggest and/or correct my procedures and/or offer some tips. Thx!
Converting HD-DVD subtitles To BLURAY subtitles
By wulf109 in forum Blu-ray RippingReplies: 1Last Post: 7th Sep 2014, 07:15 -
How to add Subtitles to original DVD whitout loosing original subtitles ?
By Chainsaw_1 in forum Newbie / General discussionsReplies: 2Last Post: 6th Jan 2010, 13:52 -
DVD software player- raise subtitles to top of scrn/ simultaneous subtitles
By jimdagys in forum Software PlayingReplies: 8Last Post: 6th Dec 2009, 18:30 -
Converting AVI to DVD plus Subtitles (Loss of quality on subtitles)
By somenho in forum ffmpegX general discussionReplies: 2Last Post: 27th Aug 2009, 10:23 -
Burning .mkv file with .ass subtitles to DVD WITH the subtitles
By isfjinfj in forum Authoring (DVD)Replies: 2Last Post: 23rd Jun 2009, 17:28
