hi! i'm new here and i seem to be having difficulty in the conversion thingie .. i can't seen to conever my .avi to mpg .. when i use TMPGEnc, there's always an erro .. what does this mean "File E:\My Downloads\mahoromatic_2.avi can not open, or unsupported"???![]()
that's the problem that i've encountered .. thuogh i can still play the said .avi in Windows Media Player .. is there another way wherein i can convery this .avi file??
i am also having this same problem--SOMEONE HEEEELPOriginally Posted by dOnnskI
I had the same problem, but then I downloaded Nimo50-build5.exe and went throught the steps to install it (there will be a warning, that if you have some kind of graphics card not to install a certian portion... pay attention to this while installing!!) Walla... Problem solved, It updated the codec's in TMPGEnc, to allow conversion..... I hope this helps..
You can get Nimo50 from the tools section to the right hand side of the screen under codec's (but I was unable to sucessfully download and install it from that site... I had to do a search in msn search for NIMO, and go from there.) have fun.-------------------------------------
"life is a garden, Dig it!" Joe Dirt
i think your problem is that you have a newer version of TMPGEnc. I had same problem. Try version beta 12a
How to batch convert mpg to avi
By roberta in forum Newbie / General discussionsReplies: 3Last Post: 18th Apr 2011, 17:17 -
How Do I convert mpg or avi to vob?
By PHNeedsHelp in forum Authoring (DVD)Replies: 1Last Post: 9th Sep 2009, 14:29 -
Convert avi, mpg etc. to mkv?
By manutd in forum Video ConversionReplies: 9Last Post: 16th Aug 2008, 17:56 -
How to convert an mpg file to avi
By spyros in forum Newbie / General discussionsReplies: 1Last Post: 9th Apr 2008, 16:02 -
Need To Convert VOB 16:9 to 4:3 AVI or MPG
By hjordan in forum Video ConversionReplies: 1Last Post: 6th Oct 2007, 22:17
