I have a video that has the audio horribly out of synch and I was wondering how to correct it.
Media info reports:
Video: English 6 938 Kbps 1920x1040 (16:9) @ 23.976Fps AVC (Main@L4.0) (CABAC/4 Ref Frames)
Audio: DTS 510Kbps 48KHz, 24 Bits
In an MKV container.
How do I best go about synching the audio?
Results 1 to 10 of 10
Are your computer specs correct? Athlon 3500+ ? If so, it's more likely a CPU/playback problem (not fast enough)
I seem to recall somebody posting something about that processor, something to the extent that we shouldnt whine about playback and I guess thats finally coming around to bite me in my ---.
I have hundreds of videos that I have zero problems with, why is this one difficult? The display size? This is one of very few 1080's I have.
Also on a different subject, I am converting a DVD I own to 264 MKV and it has a DTS soundtrack but in the dropdown audio codec section DTS isnt offerred (every other conversion I've done with DTS there has always been a DTS passthru option) so what do I assign as a codec from the choices of: AAC (faac), MP3 (lame), AC3 Passthru, AC3 (ffmpeg)? I really dont understand why DTS isnt showing. -
Yes, dimensions and type of compression. HD video , and h.264 compression both require tremendous more processing power to decode than SD video, and MPEG2 compression (DVD) . At minimum you need a dual core
If you check the file on another computer (maybe a friend's house), you can rule out problems with the file
What software ? Maybe the one you are using doesn't offer copying audioAlso on a different subject, I am converting a DVD I own to 264 MKV and it has a DTS soundtrack but in the dropdown audio codec section DTS isnt offerred (every other conversion I've done with DTS there has always been a DTS passthru option) so what do I assign as a codec from the choices of: AAC (faac), MP3 (lame), AC3 Passthru, AC3 (ffmpeg)? I really dont understand why DTS isnt showing.
Or you can demux it and remux it into the mkv container with mkvtoolnix -
I have a 6 core processor: AMD Phenom(tm) II X6 1065T Processor (6 CPUs), ~2.9GHz
And thanks you so much for the incredibly fast replies, I really appreciate it. -
So you still have sync issues with the x6 playback ??
If so, what software for playback ?
Describe the sync issues: is it progressively worsening, or constantly out of sync (e.g. 1 sec all the way through) -
To further complicate things I am viewing the movie through a Boxee Box. The thing is that I havent had any problems with any other vids, the synch has never been a problem.
The synch starts fine then gets worse -
I have found on some media boxes DTS is too much to handle. I usually convert DTS to AC3 and then it seems to work fine.
Out of synch audio
By Maxwellbest in forum Video ConversionReplies: 4Last Post: 20th Jan 2008, 10:33 -
Audio At strat in Synch , along of Movie Lost Synch with Video !!!!!
By p_samimi in forum AudioReplies: 9Last Post: 12th Jan 2008, 23:47 -
audio synch
By Usagi in forum DVD RippingReplies: 5Last Post: 28th Dec 2007, 19:11 -
Horrible audio quality when trying to capture from cvbs
By yadav in forum Newbie / General discussionsReplies: 1Last Post: 19th Nov 2007, 12:59 -
Audio goes out of synch
By Semaphoric in forum Authoring (DVD)Replies: 3Last Post: 27th Sep 2007, 22:01
