hello.. Just built my first PC.
im having trouble getting the full output settings for my monitor. My video card is AMD Radeon HD 6800 series, and my monitor is an Asus VE248. I've been fiddling with the HDTV settings in the AMD Vision Engine Control Center but to no avail...I also have been setting my monitor to HDMI after turning my computer completely off and back on again and no luck...my DVI settings work fine but I just cannot get anything to come up on my display for HDMI. please help![]()
Moving you to our computer section.
No I don't know why it wont work. But the DVI works as fine has HDMI...if you don't need any audio then.
LED MONITOR - HDMI to DVI-D cable, HDMI media player not working?
By krishn in forum DVB / IPTVReplies: 16Last Post: 25th Feb 2012, 16:20 -
Audio doesn't work on HDMI. Something wrong with the TV?
By Xavier in forum Software PlayingReplies: 1Last Post: 14th Oct 2009, 00:07 -
xbox 360 hdmi problem (hdmi works on other hdtvs but not mine
By dmiklo in forum Capturing and VCRReplies: 0Last Post: 23rd Sep 2009, 16:51 -
multimedia player connection via hdmi but monitor doesnt have hdmi slot
By ozy666 in forum DVB / IPTVReplies: 1Last Post: 25th Apr 2009, 09:40 -
Will a DVI-D to HDMI cable work for this setup?
By anthojoe in forum DVB / IPTVReplies: 1Last Post: 27th Nov 2007, 12:59
