Hi, i want to Re-Edit Titanic Original DVD Rip by including 44 min of deleted scenes through sony vegas pro 11. but how can i render this whole file 'as it is ' without affecting any increase in video file size ? are there any rendering options ? last time i made a music video for dark knight where the output file size was 900 mb for 10 min video. so this time i like to be on perfection. please help me friends if u have any idea regarding vegas pro 11.. great thanks.. have a nice day..!
You want to add 44 minutes to a 2 hour+(?) video without increasing the file size ?
OK. It can be done but to do it you will need to reduce the bit rate for the video so you end up losing quality.
If you want the video 'as is' you retain the bit rate so increase the file size. Look for an option for 'smart rendering'. That should not re-encode any video. -
How to 'smart render': Your project MUST match the clip(s) you are editing. Any differences and the clip(s) will be re-rendered. You can set the project properties to match a clip and then import that clip into the timeline. On the preferences tab you will see the option re long gop re-rendering. I think that is ticked by default so smart rendering should occur if all the other conditions are met.
However, you are importing more than one clip in your edit. The chances are that the properties of these clips will NOT be identical so some of these will still be re-rendered.
Sony Vegas Pro 10 - video/audio out of synch after render
By Acester47 in forum EditingReplies: 4Last Post: 1st Jul 2011, 14:06 -
First project sony vegas pro 10. Now first minute render corrupted
By sevenofone in forum EditingReplies: 1Last Post: 23rd Feb 2011, 21:57 -
Best render for 4:3 video using Sony Vegas pro 10 for youtube
By fuzzblaster in forum Video ConversionReplies: 0Last Post: 9th Jan 2011, 13:18 -
Sony Vegas Pro 9: Batch Render Clips Separated by Markers
By mltwitz in forum EditingReplies: 0Last Post: 5th Apr 2010, 15:41 -
Sony Vegas Pro 9 Render Settings?
By Wickwire in forum Video Streaming DownloadingReplies: 8Last Post: 28th Dec 2009, 09:46
