Please please tell me how to play Uncompressed RGB (AVI)
How to import Uncompressed RGB (AVI) in After effects and in which version.
Closed Thread
Results 1 to 30 of 34
Every video app I've ever used (>hundreds) has been able to play Uncompressed RGB (AVI).
The problem is most likely NOT "can it play it?", but rather "can it play it smoothly?" and that's a different matter altogether.
Uncompressed RGB (AVI or any other kind of container) is VERY dependent upon resolution:
1/4 D1 (~352x240, 24bit @ 30fps) = 352 * 240 * 24 * 30 = 58 Mbps (not counting audio, etc)
D1 (720x480, 24bit @ 30fps) = 720 * 480 * 24 * 30 = 237 Mbps
HD (1920x1080, 24 @ 30fps) = 1920 * 1080 * 24 * 30 = 1.39 Gbps
(btw, 4k stereoscopic hdr @ 48fps = 3996 *2160 * 48 * 48 *2 = 37 Gbps!)
So the 1/4 D1 can be played in realtime on many modern desktops, the D1 can only be played on very powerful PCs that use a quad Raid0 (or similar) hard drive setup and other infrastructure optimizations, and the HD can probably only be played on a few "super-computer" setups (like Hollywood "cloud servers").
Those are the facts, no way of getting around them without making some compromises - which most of the time are in the form of ... COMPRESSION.
Can you post the details from the avi? Use mediainfo, open video and View->text.
Cornucopia SirSir should i send you that file so that you ll go through and tell me how can i use that file , please tell me your email id
sir may i send you that file so that you will come to know and tell us that how to play or convert then play or import it in after effects.
after effects will accept uncompressed 8bpc RGB/AVI natively (all versions)
Most likely you won't get realtime playback for HD , you have to use ram preview in AE
Do you not have AE installed on your computer ?
Is there some other problem getting the file to work ?
If so, use mediainfo (view=>text) copy & paste the report back here
What is the source of the file (where is it from, a camera? what capture card? how was it transferred,e tc...)
If you can't figure it out, you can post a sample using a free hosting site e.g. mediafire.com, sendspace.com , or if it's <30MB, you can post it directly to this website
What version of AE are you using? What OS ? (Mac/PC) ?
Answer the previous questions please, regarding mediainfo and where the file is from
Is it possible file is damaged/corrupted ?
Can you open the AVI in virtualdub ?
i dont have ultra fx2. But if it works there for you, then import it into there then export something else e.g. tiff or png image sequence, or uncompressed AVI again (with header) . The you can use that export in any program like AE
The file you have uploaded is missing header information (damaged)
But these are not typical files. They are damaged and missing critical information that makes them unusable in most programs
Ask your friend to export something else (e.g. RGBA png sequence) , or even use lossless video compression e.g. lagarith RGBA
undamaged , uncompressed 8bpc RGBA/AVI will open in almost ANY application for windows, even free ones
What is uncompressed AVI?
By andrewjameshoward in forum Capturing and VCRReplies: 35Last Post: 2nd Nov 2012, 08:56 -
Exporting from uncompressed AVI to uncompressed MOV
By courtneye in forum Video ConversionReplies: 0Last Post: 9th Jul 2010, 09:20 -
Uncompressed 24bits RGB AVI - how to convert
By mooplesdooples in forum Video ConversionReplies: 1Last Post: 4th Sep 2009, 22:08 -
rmvb to avi in linux command HOWTO ! ?
By Gilberts in forum LinuxReplies: 1Last Post: 24th Oct 2008, 21:07 -
H264 (MKV) to Uncompressed RGB (AVI)
By ta2 in forum Video ConversionReplies: 2Last Post: 22nd Feb 2008, 12:00
