Hi Everyone,
I purchased a Elite Video BVP+ (Broadcast Video Processor) off of ebay. However, there is a 20 pin connector that is supposed to connect the 2 circuit boards (I guess) inside. When I received the box, the cable was disconnected.
The good thing is the 20 pin connector and cable ('looks' like an IDE or Floppy disk drive cable from a PC to give you a feel for what it looks like) is within the BVP+ unit itself. It's just randomly found in the unit, but is disconnected.
The two circuit boards say "COPYRIGHT 1996 VERSACHROME". However, I am not sure which is the correct pinouts? What is PIN 1 on each of the boards?
If anyone has a BVP+ and can just take the lid off (4 screws), could you please let me know which is PIN1 for each circuit board? Or maybe someone can snap a quick picture for me?
The two 20 pin connectors on the circuit board are labled H001 and H002. I only have one 2 wire cable going from H003 to H004 between the two circuit boards. Currently, H001 and H002 remain disconnected right now between the two circuit cards.
As a side note, I've noticed there is a 14 pin connector as well that is not connected to anything. My guess is that perhaps this 14 pin connector may be for jumpers? Not sure.
Thanks,
Jason
Hi Jason,
Just connect H001 to H002 using the ribbon cable connector. If you look at the unit from the front, the red wire on the ribbon cable should be on the far left.
ipod touch 8 gig, new unit only shows a white usb cable/itune .. [RESOLVED]
By vhelp in forum Portable VideoReplies: 1Last Post: 28th Nov 2010, 21:05 -
Xbox 360(elite)/PS3 video capture help. Monitor no components!
By DonkeyKongStar in forum Capturing and VCRReplies: 0Last Post: 11th Jul 2009, 15:09 -
Video Capture with ATI TV Wonder Elite on Vista Ultimate
By Petes457 in forum Capturing and VCRReplies: 2Last Post: 30th May 2008, 09:55 -
Elite Video BVP4+
By 22west in forum RestorationReplies: 2Last Post: 31st Dec 2007, 14:42
