Hi I am currently using DVD Architect 5.0 and am trying to render a home movie which goes for about 1hr15min.
The render time is 40hrs and 40mins and I was wondering if there was a way to speed this up or is it that this is normal.
Using WinXP. AMD Phenom Quad core 3.4GHz, 4GB DDR3(1333MHz) RAM, 512MB Video.
Also Vegas renders the source file in less than 4hrs so I don't know why exactly, that it has to take the better part of 2 days to render them to Blu-Ray.
DVD Architect 5.0 is old and pre-Blu-Ray support. Current version is 11.
What is your source format and project setting? Vegas 5.0 was the first attempt at HDV support. It had some bugs that I forget.
Normal workflow is to set project to source format (e.g. HDV), then encode ("render as") assets in Vegas. Then import rendered assets into DVDA, add menus and chapters, then output. Although DVDA will attempt to re-render non-compliant assets, you have much less control than rendering in Vegas.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
I'm using Vegas 10 to put the files in a valid format but the latest version of DVD Architect is 5.0 which I'm using
Ok, both are packaged together. V11 Vegas and V5.2 DVDA.
So what about the workflow I suggested?Recommends: Kiva.org - Loans that change lives.
I experimented with the method you mentioned. All seems to be working smoothly it's going now. Can't wait till it's finished so I can test the disc in my player. Thank You
Ulead Video Studio 11+ DVD Burning takes very long time
By chrayf in forum Newbie / General discussionsReplies: 3Last Post: 10th Mar 2012, 14:43 -
It takes a thief
By zoobie in forum Off topicReplies: 5Last Post: 16th Mar 2009, 12:59 -
Encore takes error
By Nikkiss in forum Authoring (DVD)Replies: 1Last Post: 3rd Nov 2008, 10:04 -
Backing up HD takes too long?
By videobread in forum ComputerReplies: 4Last Post: 26th Jul 2008, 13:17 -
Tyra takes her pants off on tv...
By Cirone in forum Off topicReplies: 6Last Post: 15th Feb 2008, 14:43
