HI everybody,
It's been a while since I've been around. Anyway I have a folder full of flv's that have the correct time but not the correct meta keyframe info. Is there a program I can tell it to batch correct all flv's to a certain amount of keyframes?
second question; I know from a few years back there was no way to import flv's into virtualdub and still keep the nellymoser audio. Has there been any plugins made that will import the flv with the nellymoser audio?
Nick
1) Try flvmdi , or the gui flvmdigui
http://www.buraks.com/flvmdi/
Or you can try a .bat file with flvtool or flvtool++
2) maybe with the directshow driver plugin (with ffdshow installed, and nellymoser enabled in the audio configuration) , or you can through avisynth with an .avs and ffmpegsource2
The problem is, flv's with nellymoser are usually VFR, so you will get sync issues trying to edit it, and unless you use a container that supports VFR with timecodes (e.g .mkv, .flv)
Question about valuable part in neck of picture tube
By jimdagys in forum Newbie / General discussionsReplies: 15Last Post: 1st Dec 2010, 07:11 -
how can i edit a small part inside a movie and make that part look bigger?
By xxquatroxx in forum EditingReplies: 1Last Post: 24th May 2010, 15:32 -
TMPGEnc cannot open the video part of the file, only the audio part can.
By dzsoul in forum Authoring (DVD)Replies: 15Last Post: 3rd Apr 2009, 08:36 -
BTF part 3 question - why not use gas from the second delorian????
By yoda313 in forum Off topicReplies: 14Last Post: 26th Jul 2008, 20:09 -
How cut part of .flv video?
By method in forum Newbie / General discussionsReplies: 9Last Post: 9th Nov 2007, 08:31
