Hi,
since 3 days i try to find out which parameter for ffpmeg I have to use to get a video compiled with this parameters:
I have problems to find the correct settings for mbaff=0 and constrained_intra=0. Can anybody help please?Code:ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : Baseline@L3.0 Format settings, CABAC : No Format settings, ReFrames : 2 frames Codec ID : avc1 Codec ID/Info : Advanced Video Coding Duration : 46s 547ms Bit rate mode : Variable Bit rate : 3 196 Kbps Maximum bit rate : 7 009 Kbps Width : 640 pixels Height : 264 pixels Display aspect ratio : 2.40:1 Original display aspect ratio : 2.40:1 Frame rate mode : Constant Frame rate : 23.976 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.789 Writing library : x264 core 85 r1442 781d300 Encoding settings : cabac=0 / ref=2 / deblock=1:0:0 / analyse=0x1:0x111 / me=hex / subme=6 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / mbaff=0 / constrained_intra=0 / bframes=0 / wpredp=0 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=30 / rc=crf / mbtree=1 / crf=18.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Thanks the parameter works for "constrained_intra=0" but not for mbaff and not for "wpredp=0" My current output is:
What I want is a video for mobile devices (Android 2.2-Android 4.0.3 + iphone 3 - 4s).Code:cabac=0 / ref=2 / deblock=1:0:0 / analyse=0x1:0x111 / me=hex / subme=6 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=0 / weightp=0 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=30 / rc=crf / mbtree=1 / crf=18.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
With the current settings i can play the video on Android > 2.2 + iphone > 3s with ios 5). Have you any other idea to get this working?
Thanks [guerilla]
seeing the commands ffmpegX sends to ffmpeg
By cablet in forum ffmpegX general discussionReplies: 1Last Post: 6th Jul 2010, 16:02 -
Are my audio commands are right?
By php111 in forum AudioReplies: 0Last Post: 13th Mar 2010, 12:11 -
Commands-how to resume a different VTS?
By MrMoody in forum Authoring (DVD)Replies: 7Last Post: 28th Apr 2009, 12:04 -
DVD VM Commands
By TonitoDJ in forum Authoring (DVD)Replies: 1Last Post: 24th Nov 2008, 09:55 -
Following cell commands
By levick in forum Authoring (DVD)Replies: 1Last Post: 21st Aug 2007, 21:57
