Dear Sir
I would like to download &edit my 1080/60p video of Panasonic HDC-HS900 .My PC has: HDMI,PCIe,USB2,USB3 .What is the best way
to do it?
Intel core: i5,2.67Ghz,4GB RAM,2 ATI 5750 graphics cards(1GB each)
Thx
Micha
Did you read the manual? Copy the files using USB. The quality won't change no matter what program you use to transfer them this way, but if you want to preserve metadata you may want to use the included software.
Panasonic HDC HS900
By Ravelco in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 8Last Post: 17th Aug 2012, 17:40 -
Panasonic HDC-TM900
By pepegot1 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 28th Aug 2011, 12:51 -
Panasonic HDC-TM55k, anybody using it?
By twister6 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 23Last Post: 26th Dec 2010, 09:04 -
Struggling with Panasonic HDC-SD5
By khan.cross in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 15Last Post: 5th Aug 2010, 16:49 -
Panasonic HDC-SD60
By jvidia in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 16th Jun 2010, 09:33
