Hi, I have a semi-old XP box, that I no use for as such and would like to take the two matched 250 Gb hard drives out to use as external hard drives. They are currently part of a striped set. Can I just remove them and pop them into a USB docking station and reformat them there?
Results 1 to 10 of 10
Yes.
Yes ... go for it ... take all those X rated movies and stash them on them thar drives and make room for some more X rated movies ...
If you wanted to keep them as RAID0 (and you had set up the RAID0 in software, within XP's Disc Mgmt utility), you might not even have to reformat them.
Of course, if you don't care about the current data on them, it doesn't hurt to "refresh" them with a new formatting either.
I've got a set of RAID0, a set of RAID1, and a set of RAID10, all SATA, that I can use in eSATA enclosures which makes for very fast and/or very secure access to important portable media.
Scott -
Thanks, that sound like a great idea, but I don't understand how you can use RAID sets in enclosures. Don't all the discs within the RAID have to be mounted at once and physically connected to each other?
Yes, they were, but that was inside the old XP box that I want to get rid of while keeping these drives for external storage by using them in a USB docking station, if I can.
hard drives
By Willy5157 in forum ComputerReplies: 7Last Post: 23rd Oct 2009, 05:16 -
Hard Drives
By hardy in forum ComputerReplies: 16Last Post: 27th Jun 2009, 19:00 -
2 hard drives
By danl_9x in forum ComputerReplies: 8Last Post: 8th Feb 2009, 23:55 -
Hard Drives
By jason in forum Newbie / General discussionsReplies: 7Last Post: 14th Apr 2008, 12:50 -
My dvd recorder crashed, can I salvage the hard drive?
By missparker10 in forum DVD & Blu-ray RecordersReplies: 26Last Post: 25th Oct 2007, 12:29
