Try DVDFab and download streaming video, copy, convert or make Blu-rays,DVDs! Download free trial !
    Mar 2009
    I am new to virtualdub (64), encountering 2 issues
    1. great picture but intermittent flashing on lower part of pic, seems to be the top of the same pic flashing on the bottom of the screen.
    2. very low volume on audio, set at maximum
    Doesn't seem to be using a lot of cpu, 5 - 30%
    Please give more information about your source video, use mediainfo, open your video and change to view->text and copy and paste the info in this thread. And then tell us what you are converting to, video and audio codec and if you are using any filters.
    And maybe also post a screenshot or short sample of the video.
    Mar 2009
    I am using a honestech converter box connected to an Atlantic Scientific DVR with composite connections. Same issues when using the Honestech software or the virtualdub. This is all new to me.
    1.The sound is barely audible.
    2. I get a intermitten flashing on the bottom of the screen which looks like it is duplicating part of the picture a second time, over laying 10 - 25% of the bottom of the main picture. It doesn't remain, just flashes long enough to see it.
    Windows 7/ 64bit
    General
    Complete name : C:\Users\bob\Desktop\test2.avi
    Format : AVI
    File size : 10.0 KiB
    Video
    Format : YUV
    Codec ID : YUY2
    Codec ID/Info : YUV 4:2:2 as for UYVY but with different component ordering within the u_int32 macropixel
    Width : 720 pixels
    Height : 360 pixels
    Display aspect ratio : 2.000
    Frame rate : 29.970 fps
    Color space : YUV
    Chroma subsampling : 4:2:2
    Compression mode : Lossless
    Audio
    Format : PCM
    Format settings, Endianness : Little
    Format settings, Sign : Signed
    Codec ID : 1
    Bit rate mode : Constant
    Bit rate : 1 536 Kbps
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Bit depth : 16 bits
