    Jan 2012
    Inparis
ID:	10369Click image for larger version
ID:	10372Click image for larger version
    Hello, has anyone use this capture device?
    This is a cheap stuff made in China.
    with composite connection, When i record tv program using this device, recorded video is crap.
    I dont think i will get better quality if i connect it with s-video cable,
    bcuz i get good enough quality of streaming video even using composite cable,
    the issue is the output video compression quality (using capture software that came with it)
    the software is "one touch grabber" or "EZ grabber"
    the best record quality available is DVD.
    I need to know if somebody using this device, any other alternative software to record video with better compression?
    Actually I wanna buy easycap, bcuz easycap can use VirtualDub for recording, that can install additional codecs,
    but easycap not available in the shop, only got this one n this device cant be used with virtualdub.
    to bad this device got no exact name, otherwise i can do my own research.
    what this device name actually? it only says "usb 2.0 video & audio grabber" and also "usb av grabber", it's too general and hard to google it.
  2. Winstar Ws-dvr203av Usb 2.0 Audio Video Grabber
    http://compare.ebay.com/like/120673578856?_lwgsi=y&ltyp=AllFixedPriceItemTypes&var=sbar
    I got that by googling the Model number on your pic
    http://www.win-star.com/eshop/goods.php?id=82
