I am curious to find out if anyone has an issue with ffmpeg encoding to xvid with ac3 5.1 audio. I can't seem to make it work.
I am doing dvd backups that I stream to my PS3, xvid is the only way to keep soft subtitles, and I would like to just copy the 5.1 ac3 audio typically found on those files. It would work with xvid + aac 5.1, but I want to avoid the ac3 to aac conversion. And, when I need the subtitles, I want to use xvid instead of h.264.
When I say I can play a compressed video, it means I can stream it to the PS3 (with ps3mediaserver) and send to my receiver the full audio in Dolby Digital 5.1 channels.
Here is what works:
- I can play on the PS3 a VOB file with ac3 5.1 channels
- I can encode and play a compressed file to mpg with ac3 5.1
- gspot tells me that I have the codecs for ac3 5.1
- I can encode and play a compressed file with H.264 mp4 and ac3 5.1 only if I re-encode the audio (i.e. -acodec ac3 -ac 6 -ar 48000 -ab 448k, but not -acodec copy) although the original audio is ac3 5.1
- I can encode and play a compressed file with libxvid and aac 5.1 (-acodec libfaac -ac 6 -ar 48000 -ab 448k)
- I can use autoGK and get an excellent video with Xvid + ac3 5.1 passthrough audio (but I want to use a command line tool)
Here is what doesn't work for me:I think I have seen inconclusive threads on similar issues. I would appreciate if anyone could share any insight.
- Pretty much any compression to xvid + ac3 5.1 audio, whether the source is a vob file with mpeg2 and ac3 5.1 audio, or a separate video from avisynth and a separate ac3 5.1 audio file, and whether the audio is passthrough or re-converted to ac3 5.1.
- Compression to H.264 mp4 with -acodec copy of the source ac3 5.1 audio stream doesn't work either (but re-converting to ac3 5.1 does).
I did most of my testing with an ffmpeg version which I compiled on July 26, 2011 with the latest version at that time. I just downloaded the latest build today from Zeranoe's website (ffmpeg version N-36193-gf514695), which doesn't seem to improve the situation.
Thanks.
Khaver,
I haven't been able to make it work. It seemed promising, but my PS3 doesn't like it.
In case you are interested, I checked a solution that seems to work for me. See Nologic's suggestion at this page.
EDIT: The mp4box solution looked great, but I realized that, under normal circumstances, the XVID video is converted to mp4, which defeats my purpose.
Thanks again for the help.Last edited by suroit; 5th Jan 2012 at 18:29.
ffmpeg output 2gb limit? Is there one? ffmpeg stops encoding h264 @ 2gb
By BrainiakZ in forum Video ConversionReplies: 14Last Post: 30th Mar 2011, 12:04 -
Cant get ffmpeg X to work
By mac1234 in forum ffmpegX general discussionReplies: 1Last Post: 16th Sep 2010, 22:47 -
Make an xvid/avi from DVD but keep original ac3 surround sound?
By coolchris in forum Newbie / General discussionsReplies: 2Last Post: 26th Jan 2008, 07:35 -
Trying to get Yamb to work with a AC3 file to make a mp4...
By AndyD in forum AudioReplies: 2Last Post: 12th Jan 2008, 23:07 -
FFMPEG QUESTION :How do I take one frame and make a jpeg with FFMPEG?
By goheadtry in forum Newbie / General discussionsReplies: 1Last Post: 18th Sep 2007, 02:55
