I joined two avi files together ( two parts to the same movie) - using avidemux - this seems to have worked okay - I got a single playable avi file - however.
I used another program - subtitle workshop - to join the two srt files together into a single srt file - that file looks normal.
Problem: when I play the movie the subtitles only work for the first half of the movie (up to the join point) - then no subtitles on the second part no matter if I use the joined srt file or the original second srt file.
So it looks like something in the Avidemux setup that I did wrong.
Any ideas?
Fixed how? Did you join incorrectly with subtitle workshop?
(It might help other who search for same problem)Last edited by Baldrick; 4th Jan 2012 at 05:29.
In SW I missed a switch called - "recalculate time values" - this is not selected by default - seems like it should be if you are joining multiple srt files anyway?
anyway that fixed it and gives the multiple srt files one continous time progression.
Join AVI file
By czgirb in forum Video ConversionReplies: 3Last Post: 19th Jun 2011, 22:53 -
Join AVI files together ?
By terryfox in forum Newbie / General discussionsReplies: 7Last Post: 27th Apr 2009, 23:56 -
Simplest way to join 15 avi's into 1
By macbuz in forum MacReplies: 3Last Post: 20th Jan 2009, 17:06 -
how do I join several movies and add subtitles?
By dannoura in forum Newbie / General discussionsReplies: 0Last Post: 11th Apr 2008, 17:17 -
Cant join 2 AVI together!
By GangstaRap in forum EditingReplies: 2Last Post: 25th Dec 2007, 19:41
