Please,
With reference to the MKVExtractGUI-2:
Worked up to MKVToolnix version 5.1.0.
With versions MKVToolnix 5.2.0 and 5.2.1 does not work.
Just use mkvtoolnix 5.1.0 with mkvextractgui2 until it has been updated for 5.2+.
Thank you, @Baldrick,
Yes, I'm using v5.1.0.
It was only to report the problem. -
You could also post a review or in the forum over at http://sourceforge.net/projects/mkvextractgui-2/ .
They released two updates to the same version: MKVToolnix v5.2.0.
Now the MKVExtractGUI2 is running on MKVToolnix v5.2.0 from this link. -
I updated our mirror download with the new mkvtoolnix 5.2.1 windows updates.
Ok, thank you. You are very considerate, @Baldrick.
Anyway I await the solution to version 5.2.1.
For I believe that is a problem of the MKVToolnix. -
Please disregard the previous message. This is the correct message: For the MKVExtractGUI-2 v.2.2.2.6
Now, when extracting an AC3 audio, it is converted to H264.
But keeping the internal properties of AC3 audio,
and file with the correct size for the MKVToolnix v5.2.1
For the MKVToolnix v5.2.0 it creates a file H264 in which the audio extraction is 4x greater.
Using MKVExtractGUI-2 batch tool
By CasanovaFly in forum Video ConversionReplies: 4Last Post: 2nd Jan 2011, 10:05 -
Having Problems with MKVextractGUI
By PlissandrO in forum SubtitleReplies: 2Last Post: 30th Sep 2009, 04:50 -
Quick question about mkvextractgui
By draco_nite in forum Video ConversionReplies: 9Last Post: 7th Aug 2009, 18:41 -
mkvextractgui with AVC problem
By Szymus in forum Video ConversionReplies: 2Last Post: 2nd Feb 2009, 13:36 -
An issue with MKVExtractGUI
By vertical in forum Newbie / General discussionsReplies: 5Last Post: 9th Jan 2008, 02:32
