I've been trying to find a way through Compositing Mode (3D Source Alpha) and track motion to get the text of a word on the Y-axis to spin from not seeing anything to have it spin on the Y-axis (horizontally) to 0 degrees or basically the default starting text position in 2D.
The problem is that when I put the Y-axis orientation starting at 90 degrees and have it end with 0 degree it spins the WHOLE word and would like to have each individual character in the word spin on their own axis I guess you could say.
Is this possible or do I have to go through this process for each character of the word and place/space them out accordingly? Thanks!
Using Sony Vegas Pro 10 BTW
The concept of "Words" and "letters" have no counterparts in NLE terms. Like "brain" and "arm" or "finger" don't translate either.
Like if you wanted to rotate a picture of a head, but leave the brain still, the head and brain need to be separate objects.
How to Add Text Effects and Unicode Characters to MPEG-4 Subtitles
By PBear in forum User guidesReplies: 9Last Post: 20th Sep 2012, 09:15 -
sony vegas pro 8 rendering wont render video just audio and text
By bahlue18 in forum EditingReplies: 6Last Post: 12th Apr 2011, 07:31 -
Spanish subtitle characters in Sony DVD Architect
By Lastman369 in forum Authoring (DVD)Replies: 0Last Post: 13th Apr 2010, 19:42 -
Vegas 8: Overlay text in multimcamera mode?
By stantheman1976 in forum EditingReplies: 0Last Post: 4th Feb 2008, 13:08 -
Vegas rolling text question
By RKelly in forum EditingReplies: 3Last Post: 19th Jun 2007, 01:15
