I have a dreambox (500HD) and Im using Sony Vegas to edit my recorded tv-shows.
Unfortunately Sony Vegas don´t support mpeg4 ts-files (only mpeg2 ts-files).
So, what im looking for is a videoeditor that can handle mpeg4 transport streams.
Would be great if there was a software that works/looks similar to sony vegas.
All suggestions are much appreciated!
Best regards: manutd
Results 1 to 12 of 12
Thanks for the quick reply!
Unfortunately I get this message when I try to add the file: "Unsupported format. Some track was not recognized. This track was ignored." -
tv4 hd
svt hdallmänt
fullständigt namn : C:\users\****\desktop\20120103 1215 - tv4 hd - halv tta hos mig.ts
format : Mpeg-ts
filstorlek : 15,2 mib
duration/string : 9 s 520 ms
generell bitrate : 13,1 mbps
video
menuid/string : 1405 (0x57d)
format : Avc
format/ : Advanced video codec
format_profile : High@l4.0
format_settings_cabac/string : Ja
format_settings_refframes/string : 4 frame
format_settings_gop : M=4, n=12
codecid : 27
duration/string : 9 s 620 ms
bitrate : 11,9 mbps
bredd : 1 920 pixlar
höjd : 1 080 pixlar
bildförhållande : 16:9
bildhastighet (frame rate) : 25,000 fps
colorspace : Yuv
chromasubsampling : 4:2:0
bitdepth/string : 8 bits
bits/(pixel*frame) : 0.229
streamsize/string : 13,6 mib (90%)
colour_primaries : Bt.709-5, bt.1361, iec 61966-2-4, smpte rp177
transfer_characteristics : Bt.709-5, bt.1361
matrix_coefficients : Bt.709-5, bt.1361, iec 61966-2-4 709, smpte rp177
audio
format : Ac-3
format/ : Audio coding 3
format_settings_modeextension : Cm (complete main)
codecid : 6
duration/string : 9 s 472 ms
bitrate : 576 kbps
kanal(er) : 6 kanaler
kanalplatser : Front: L c r, side: L r, lfe
samplingstakt : 48,0 khz
bitdepth/string : 16 bits
video fördröjning : -783 ms
streamsize/string : 666 kib (4%)
språk : Svenska
meny
list/string : 512 (0x200) (avc) / 641 (0x281) (ac-3, svenska)
språk : / / engelska
allmänt
fullständigt namn : C:\users\***\desktop\20120103 1245 - svt1 hd - skidor_ vrldscupen tour de ski.ts
format : Mpeg-ts
filstorlek : 11,8 mib
duration/string : 5 s 997 ms
generell bitrate : 15,9 mbps
video
menuid/string : 1406 (0x57e)
format : Avc
format_settings_refframes/string : 6 frame
format_settings_gop : M=4, n=32
codecid : 27
duration/string : 5 s 380 ms
bitrate : 14,4 mbps
bredd : 1 280 pixlar
höjd : 720 pixlar
bildhastighet (frame rate) : 50,000 fps
colorspace : Yuv
bits/(pixel*frame) : 0.312
streamsize/string : 9,22 mib (78%)
audio #1
format : Mpeg audio
format_version : Version 1
format_profile : Layer 2
codecid : 4
duration/string : 5 s 976 ms
bitrate : 256 kbps
kanal(er) : 2 kanaler
video fördröjning : -570 ms
streamsize/string : 187 kib (2%)
språk : Svenska
audio #2
format : Ac-3
codecid : 6
duration/string : 5 s 920 ms
bitrate : 448 kbps
video fördröjning : -556 ms
streamsize/string : 324 kib (3%)
språk : Svenska
text
id : 576 (0x240)-100
format : Teletext
språk : Svenska
meny
list/string : 512 (0x200) (avc) / 576 (0x240) () / 640 (0x280) (mpeg audio, svenska) / 641 (0x281) (ac-3, svenska)
språk : / / / engelska / / engelskaLast edited by manutd; 3rd Jan 2012 at 05:49.
Give up.
Do you have a shorter sample you can post so we can try convert?Last edited by Baldrick; 3rd Jan 2012 at 06:46.
Here is a short sample: http://www.fileserve.com/file/8BZwrp9/20120103 1341 - SVT1 HD - Skidor_ Vrldscupen Tour de ski.ts
You are free to laborate with it as much as you want
I tried xmedia recode and it could remux to a m2ts and mp4, try open in vegas:
edit: But I couldn't convert to any other format in xmedia recode...hmm...Last edited by Baldrick; 3rd Jan 2012 at 07:03.
I really appreciate your help! Unfortunately I get this messages:
"File C:\Users\*****\Desktop\20120103 1341 - SVT1 HD - Skidor_ Vrldscupen Tour de ski.mp4 could not be opened."
and
"An error occurred during the current operation. An exception has occurred" when I try to open the m2ts-file...
Guess I´ll just have to find another software to edit my hd-clips.
I´ve used VideoReDo but it´s not even close to the potential that Vegas gives you. -
I can convert the ts to an avi with lossless lagarith with virtualdub and the ffmpeg input plugin. But it's 40MB/second...and even bigger for 1920x1080 video.
mpeg4-ts - how to edit? Need to cut fragments and join two files
By relu84 in forum Newbie / General discussionsReplies: 2Last Post: 18th Jan 2011, 07:01 -
HOW TO EDIT MPEG4 FILES IN (DIVX).AVI, .mkv and .mp4 Containers
By jhb50 in forum User guidesReplies: 0Last Post: 18th Jul 2009, 22:32 -
What is the best way to edit MPEG4 files
By Paul W in forum Newbie / General discussionsReplies: 8Last Post: 1st Apr 2008, 11:32 -
edit w/o recompressing mpeg4 and wmv
By mrready in forum EditingReplies: 3Last Post: 29th Jan 2008, 08:56 -
best software for converting avi to mpeg4
By woo124 in forum Video ConversionReplies: 4Last Post: 7th Sep 2007, 14:01
