What's the most "Device Compatible" container? is it, .mp4 or .mkv?
Results 1 to 12 of 12
and what about DXVA? that's a type of setting right? b-frames and stuff.. does that affect the playback?
http://www.kiva.org/about -
All those things effect playback. DXVA is Microsoft's DirectX Video Acceleration libarary. Encoding with DXVA compatible settings will assures that DXVA will play the file properly. All devices have limitations on what containers, codecs, and codec features they support.
so If I encode in DXVA, will that file still play in the normal XBOX WDTV and stuff?
DXVA is a MS specification that can use a compatible Windows PC (Or Xbox 360) video card to help with playback processing (Hardware processing) of video. It's not a video format.
http://en.wikipedia.org/wiki/DirectX_Video_Acceleration -
The Xbox 360 can play video encoded to the DXVA standard. I'm pretty sure the PS3 can handle it too. At least as far as h.264 is concerned.
is there a tool that could be used to check "with what devices this video can be played with"?
As far as I know, not specifically. There are tools that can tell you what profile@level is flagged. Though the flag may not reflect the actual video content.
http://en.wikipedia.org/wiki/H.264/MPEG-4_AVC#Profiles
http://en.wikipedia.org/wiki/H.264/MPEG-4_AVC#Levels
x264 MKV to MP4: "WEB OPTIMIZED"? AAC? CRF?
By J81CHAT in forum Video ConversionReplies: 5Last Post: 27th Feb 2012, 17:52 -
ffmpeg GUI that can "copy" into a different container?
By AlanHK in forum Video ConversionReplies: 4Last Post: 22nd Jul 2010, 03:37 -
"stretching" or "cramming" aspect ratio when I convert .avi to MP4
By Agent Bauer in forum ffmpegX general discussionReplies: 3Last Post: 21st Mar 2010, 11:30 -
".mkv" to "DVD" with CCE encoder
By chrchr in forum Authoring (DVD)Replies: 17Last Post: 28th Jan 2010, 14:01 -
Review "HYFAI" MP3/MP4 "Nano" clone from ebay
By NG in forum Portable VideoReplies: 29Last Post: 18th Sep 2007, 06:45
