Hi
I went to http://www.x264bluray.com/home/720p-encoding
re: Authoring a professional Blu-ray Disc with x264
all the examples use two pass encoding, e.g.:
720p23.976 / 720p24
x264 --bitrate XXXXX --preset veryslow --tune film --bluray-compat --vbv-maxrate 40000 --vbv-bufsize 30000 --level 4.1 --keyint 24 --open-gop --slices 4 --colorprim "bt709" --transfer "bt709" --colormatrix "bt709" --sar 1:1 --pass 1 -o out.264 input.file
x264 --bitrate XXXXX --preset veryslow --tune film --bluray-compat --vbv-maxrate 40000 --vbv-bufsize 30000 --level 4.1 --keyint 24 --open-gop --slices 4 --colorprim "bt709" --transfer "bt709" --colormatrix "bt709" --sar 1:1 --pass 2 -o out.264 input.file
and from a short thread at doom9:
Could someone please check the following and let me know if it should produce a blu ray compliant encode?
--demuxer ffms --fps 24000/1001 --force-cfr --crf 18 --preset slow --bluray-compat --level 4.1 --tune film --keyint 24 --open-gop --pic-struct --slices 4 --sar 1:1 --partitions all --vbv-maxrate 35000 --vbv-bufsize 30000 --colorprim "bt709" --transfer "bt709" --colormatrix "bt709"
[response]
If the resolution is right and you output to .264 it should.
My question then: if I use a crf value that keeps the max bitrate under 38000 are there any disadvantages compared to using a two-pass encode?
TIA
The main disadvantage is you don' t know what bitrate (filesize) you end up with . It won't violate vbv restrictions (won't go over), but it can undersize
If you are using crf encoding with vbv, I would use lower crf value . On some sources, you might find it terribly undersized with very low bitrate
If you did encode that way and ended up with "x" bitrate, and did a 2pass encode using "x" bitrate, but other settings the same - the quality will be very very similar (there will be very slight differences) -
Thanks pdr - that's what I was thinking re not knowing the final bitrate - I suppose I could use variations of SelectRangeEvery and experiment a bit with crf values . . .
IMO , that's a huge problem when you're trying to author to a fixed capacity disc optimally, with menus & multiple streams.
IMO, the SelectRangeEvery or derivative functions are very poor predictors of final video bitrate. It's difficult to sample correctly. It might be within 5-25% of the final encode, but that's hardly accurate enough
xvid equivalent to CRF from x264
By codemaster in forum DVD RippingReplies: 4Last Post: 22nd Sep 2011, 07:08 -
Source bitrates and x264 crf settings?
By orangeboy70 in forum Newbie / General discussionsReplies: 10Last Post: 2nd May 2011, 21:15 -
X264:How do you encode in 2pass ?
By themaster1 in forum Video ConversionReplies: 9Last Post: 25th Apr 2009, 17:29 -
X264 CRF Tuning
By dannyboy48888 in forum Video ConversionReplies: 3Last Post: 22nd Mar 2009, 12:19 -
x264 CRF best for iPod encoding? Coder Options Quandary.
By radellaf in forum DVD RippingReplies: 0Last Post: 28th Mar 2008, 09:14
