Hi,
I posted this is the wrong forum (Restoration) before. Apologies for the double post.
I've a question about capturing video to work with remotely. My capturing equipment is in Ireland and I currently live in the US so I have a brief window during Christmas to start getting some home videos (PAL format) on VHS tapes digitized (times flies depressingly).
The equipment I have in Ireland is:
- JVC HR-S8965 (S-VHS);
- Canopus ADVC-100;
- Laptop with Intel Core i7-2630QM (2GHz, 4-core) and 8 GB RAM (Windows 7).
I've been looking at this thread again (with loads of great information) to get an idea of what filters to use and the conclusion I reached is that I will need time to work out different settings for different videos.
My plan is to capture all the videos using WinDV or something similar in Ireland. Based on the bitrates so far, I'll be able to bring all the captures back to the US on a hard disk so I can spend time there cleaning up the video or adjusting HSV etc. if necessary.
My question is whether this workflow is a good idea i.e. is there something I should be doing during capturing to improve the quality before the encoding in WinDV? I will check all the captures to make sure they look fine but I'm still worried about hitting the problem that grannyGeek mentioned here when I'm back in the States with no access to the sources.
Please don't cross post. I removed your other thread.
Sorry about that. I shouldn't have posted this in the Restoration forum in the first place.
Thanks for the advice. I'm reading through the manuals again at the moment and think I have the appropriate settings:
- TBC and Noise Reduction (NR) on;
- Video stabilizer off (you can use this or TBC/NR but not both);
- Biconditional Equalised Signal Tracking (BEST) on. This checks the condition of the tape in use and compensates during playback "to give the best quality possible";
- Picture Control set to AUTO which is meant to provide the optimised picture benefits of the BEST picture system;
The video player is connected to the ADVC 110 using the S-video connection and L/R audio inputs. I've captured some video now (an old tape, not the home videos) and it looks as good as I expected. I've attached a screenshot from VirtualDub with the original frame on the left and a deinterlaced (blend fields, keep top field) frame on the right.
I won't actually be deinterlacing the video when I process it later. I just did this test to get an idea of what quality I can expect without any experimentation. I still have a lot of reading to do before getting started. -
Very hard to judge with a still shot, seems slightly grainy, which I hear is a common result
with the Canopus box.
Regarding the VCR's settings, perhaps somebody else will chime in with some specifics for you.
an idea for TRUE video restoration
By unclescoob in forum RestorationReplies: 36Last Post: 5th Apr 2012, 08:57 -
Looking For Video Processing Problems
By Saint_Emperor in forum EditingReplies: 8Last Post: 6th May 2011, 17:25 -
old 1988 home video with TERRIBLE slow motion - trying to edit that in 2008
By AcesOfClubs in forum RestorationReplies: 9Last Post: 28th Jan 2008, 10:49 -
By AcesOfClubs in forum Video ConversionReplies: 1Last Post: 25th Jan 2008, 13:33 -
Capture streaming video off of TNT site
By gmpoole in forum Capturing and VCRReplies: 0Last Post: 18th Aug 2007, 18:02
