    Jan 2006
    Australia
    I created a 720p MP4 file using Sony Vegas a while back and now I can't get it to play. I wiped my PC and moved the file from one hard disk to another, so I'm not sure if something got corrupted when I did that.
    If I use MediaInfo, it detects the header info ok, and Windows will also detect the header info but will not provide a thumbnail. I have tried Windows Media Player, GomPlayer, VLC, Quicktime, none of these will play the file. It detects the length of the video, but either just gives a black screen with no audio, or an error pops up.
    In the MediaInfo it says the codec is MP42. From what I've gathered, this has to do with Video For Windows, and is used specifically by Sony Vegas. I have re-installed Sony Vegas and attempted to import the video, but it doesn't recognize it as valid. I have also tried to install different VFW and MP42 codecs, but still no success.
    Here's the MediaInfo:
    General
    Complete name : C:\Users\2011.08\Desktop\MormonChurch.mp4
    Format : MPEG-4
    Format profile : Base Media / Version 2
    Codec ID : mp42
    File size : 124 MiB
    Duration : 7mn 58s
    Overall bit rate : 2 164 Kbps
    Encoded date : UTC 2009-08-19 08:47:19
    Tagged date : UTC 2011-09-22 12:57:54
    Xtra : WM/MediaClassPrimaryID
    ©TIM : 00;00;02;12
    ©TSC : 30000
    ©TSZ : 1001
    Video
    Format : AVC
    Format profile : Main@L4.2
    Format settings, CABAC : Yes
    Format settings, ReFrames : 4 frames
    Codec ID : avc1
    Duration : 7mn 58s
    Bit rate mode : Constant
    Bit rate : 2 000 Kbps
    Width : 720 pixels
    Height : 396 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 29.970 fps
    Standard : NTSC
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.234
    Stream size : 114 MiB (92%)
    Language : English
    Tagged date : UTC 2009-08-19 08:47:19
    Audio
    Format : AAC
    Format profile : LC
    Codec ID : 40
    Duration : 7mn 58s
    Bit rate mode : Variable
    Bit rate : 157 Kbps
    Maximum bit rate : 254 Kbps
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Compression mode : Lossy
    Stream size : 8.99 MiB (7%)
    Language : English
    Material_Duration : 479061
    Material_StreamSize : 9424036
    Here's a download link for anyone willing to check out the file itself:
    http://www.megaupload.com/?d=NVC7AOKP
    I fear the file got corrupted when I moved it to another hard disk, though it's probably been 10 years since I've had a file get corrupted just by moving it.
    Any help would be appreciated!
    thanks
    It doesn't seem to contain any video at all. I have tested with some editors like avidemux.
    You could try the video repair tool, extract and run the gd.exe, import the mp4 and a working mp4(with same codecs as the broken) and see if it can find any video. If it works it costs $40 to restore the full video though.
  3. "Re: Broken MP4 file - can anyone help?"
    Below, screenshots from your damaged file.
    We can help, we are dedicated to video repair:
    http://aeroquartet.com
    Regards,
    BJ
    AeroQ: When will you release treasured for windows?
    But I had to test Video Repair Tool and yes it worked. But it's out of sync.
    Download repaired video: http://www.megaupload.com/?d=XF60NIG1 .
  5. Treasured for Windows exist! It's a web app called "WebTreasured".
    Anybody can use it. To receive credentials, just enter your email here:
    http://aeroquartet.com/movierepair/windows.html
    Today it's in alpha stage. The tools has many rough edges. But we will go beta in Spring'12.
    Regards,
    Benoît
    Jan 2006
    Australia
    Wow that's amazing, thanks a lot for that! Looks like it got corrupted after all. But the whole thing seems intact.
    thanks again, and thanks to all those who had a look.
