Results 1 to 20 of 20
  1. Hi and happy new year.
    I am searching already 5 days to find a tool that can help me to rip/mux a DVD that has 14 chapters and each chapter is a different cartoon for my case. So what I need to do is to get each chapter alone and also I dont want to lose quality. Was trying to do with DVDFab but the MKV mux is not working there for me also others are stuck in 0.47% or so. In one word need other then DVDFab.
    THanks
  2. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    DVDDecrypter can rip by chapter but if the DVD has new copy protections then you will need something like AnyDVD running in the background.
  3. as I know its saving as VOB files, inst it?
  4. Originally Posted by The_Armenian View Post
    Yes, that's what ripping by chapter means. If you want some other output format, when you've finished decrypting the various chapters/cartoons, then use a conversion program to reencode them or mux into MKV or whatever you want.
  5. Originally Posted by hech54 View Post
    DVDDecrypte rmade the video narrower and I dont know why. It has same bitrate same resolution as the source but its not the same when I play it. Is there any other tool that can do this?
  6. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    No it didn't.
  7. Originally Posted by hech54 View Post
    No it didn't.
    how to make screen let me show it and u can see.
    When I watch from DVD its different then I watch from the HDD.
  8. ok I dont know how but now its same as in DVD. But I have another question. There are 14 chapters but its making 5 VOB files in my HDD. I choose to split by chapters. Why I dont get them all?
  9. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    TOOLS - SETTINGS - IFO MODE - File Splitting BY CHAPTER
  10. Originally Posted by hech54 View Post
ID:	10338Click image for larger version
    I am not getting the 14 chapters individually. I got some 5 VOB files after all. Please advice
  11. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Are you in IFO Mode?
  12. Originally Posted by hech54 View Post
    ooppss I was on file mode
  13. Originally Posted by hech54 View Post
    ok now I need some tool to MUX VOD to MKV and again dont want to loose quality.
    Thanks for all your answers
  14. ok one more question I have. So when I am watching the DVD with the player I can watch it wide screen on my 40' LED TV. When i am doing rip and convert its 4:3. how can be so when with DVD player its 16:9? and how to fix this?
  15. I'm a MEGA Super Moderator Baldrick's Avatar
    You could try dvdpatcher on one vob and set the aspect ratio to 16:9 and see how it works.
  16. I'm a MEGA Super Moderator Baldrick's Avatar
    And if you would like "real" mpg files for each chapter you can use vob2mpg pro from the dvd. But it's not free.
  17. Originally Posted by Baldrick View Post
    I really would like MKV as my TV is having some issues with other formats or I dont know what to use for it. It is so strange that there is no software that can do all at once. I mean rip DVD to separate chapters and convert to the format that I need. And not to add each file one by one. Just put the DVD in the rom and start the job.
    Now what I am doing is I rip with DVDDecrypter then converting with Handbrake. In Handbrake I add queue all the files one by one again then start converting. Its really annoying. If you know any program that can do all at once I am ready to pay for it. Please advice.
  18. Most programs don't include the decrypter because it could easily be grounds for the program getting banned. It's (as far as I know) always a two-step process - decrypt the video to the hard drive followed by the reencoding/conversion.
  19. I'm a MEGA Super Moderator Baldrick's Avatar
    Splitting by chapters is a bit strange yes. You could batch convert your vob files to mkv with something like xmedia recode or freemake video converter.
    And ignore my mpg comment...I was thinking about another thread.
  20. Originally Posted by Baldrick View Post
    Thank you for all your posts mate. I hate the DVD because of this issue not being able to convert them as I want to. But the cartoons I have are very old and very specific for me and I need them on my HDD. Will try that once too. Thanks to you and all the others for any advice.
