Hi, I am somewhat new to this more advanced video editing stuff and am experiencing a VERY frustrating problem I have been tirelessly trying to solve since 2:00 PM yesterday.
I have a video file that I am trying to burn to a DVD so that I can watch it on the most basic DVD players anywhere I go.
The file originally came as 2.0G mp4 file and I have managed to shrink it to a 690 MB wmv file.
The only problem is that when I try to use Windows DVD maker to burn to a DVD, Windows DVD Maker (WDM) says the video is 16 minutes too long although the the file size is considerably smaller than the allotment on the DVD.
The tools/software I have available is:
iMovie
Windows Movie Maker (2.6 and Live versions)
Windows DVD Maker
Blaze Media Pro trial edition
If totally necessary, I can install Adobe CS4 programs from my university..
Is there any way possible to get this file to fit onto a DVD5 with the available tools and/or any other freeware apps out there? I plan on buying the Blaze software although I cannot right now due to funds.
Thanks for your time.
				Results 1 to 18 of 18
	Yep, first go back to the MP4 and forget about shrinking it down any more. Second, ditch the crap Windows DVD Maker and use a decent DVD conversion and authoring program. Maybe try Avs2DVD or DVD Flick.
	It may be best to first read "what is dvd" at the top of the menu on the left hand side of this page. Then use the recommended programs and see which you like better.
	I might mention that a single layer DVD is really only 4.37GB. The larger size mentioned is just from an 'improper' measurement method. (Also in 'WHAT IS' DVD.)
	@redwudz- True BUT, even the larger mp4 file that I downloaded should have fit if discerning by file size. However, the D5 disc DOES say 120 minutes on it. But then again, the length of the file was 2:46:22 and DVD Maker said it was 16 minutes too long so I was all kinds of cornfused.
 Anyways... I got AVStoDVD and all of its affiliate programs installed and working and am working on getting the DVD burnt and ran into a problem.
 When I tried to select the D: drive w/ my blank DVD in it the prog told me the drive is not ready and to check for proper connection and if a disc was actually in the drive. Why's this?
 What I amcurrently attempting in order to get around this is to just burn an image to a file and will then try to use ImgBurn to burn the file to a DVD. hopefully this works.
 Any suggestions? It seems I should just be able to burn the image directly to a DVD straight from AVStoDVD.
	The program WILL allow you to write direct to a dvd disk - you do, I assume, have a dvd-burner installed in your PC.
 However, I would NEVER suggest that course of action. Better to create a folder, test the dvd so created using a software dvd player and then burn that tested folder using imgburn - the burn to disk option uses imgburn but you will waste a disk if the created disk was not to your liking.
	Yeah, I eventually figured out that's what AVStoDVD was going to do in the first place. The file path I was trying to set as D: was where AVStoDVD was wanting to put the image files prior to burning the DVD with imgburn.
 HOWEVER, although I did get the DVD burnt, the damn thing won't play on my DVD player! Is there a setting I must choose for the disc to play on a DVD player? I think the file burnt to the DVD was a .m2v file.
	On my version there are 5 settings available under 'Output'
 1. Elementary Mpeg2 Streams - that appears to be the one you have selected.
 2. Muxed Mpeg2 File - that would create a playable file with the .mpg extension.
 3. DVD Folder Structure - that is the one I recommend (to test the final dvd BEFORE burning the disk.
 4. ISO UDF Image - creates an .iso image which Imgburn can also use
 5. Burn DVD - cuts out options 3. or 4.
 If you still have the M2v file on your hdd you could still use that with option 3. to create a proper dvd disk.
  a good BOB? for DVCPRO via SDI output TO CAPTURE into Precision 690 PC?By cowtowne in forum Capturing and VCRReplies: 0Last Post: 14th Feb 2011, 12:01
  burning a dvd from an .avi file and a .wmv fileBy marlo in forum Newbie / General discussionsReplies: 3Last Post: 28th Dec 2010, 07:06
  DVD file too large to burn to disc..how can I make it fit?By Natalie88 in forum Newbie / General discussionsReplies: 4Last Post: 18th May 2010, 09:14
  converting WMV file 408mb to DVDBy jbitakis in forum Authoring (DVD)Replies: 14Last Post: 31st Oct 2008, 08:31
  Unable to fit file to dvd?By Ado in forum Video ConversionReplies: 5Last Post: 5th Aug 2007, 20:20
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
