I have this movie Monster vs Aliens in 1/2 sbs. When I stream it from my computer with WDTV Live, it plays fine on my Panasonic 50ST30 but with Dutch Subtitles . When I try turn off the dutch subtitles , the movie suddenly becomes 2D and I can only then watch it in 2D to 3D mode. Not sure why.
I tried to remove the subs using MKVMergeGUI but there is no subtitle track shown . I only see the video track and two sound tracks . Does this mean the subs are hard coded in Dutch or is there anything I should do to view the subs? ( if they are hard coded then why can I remove them in 2D mode? )
BTW I am using version 4xx of MKVmerge .
Any suggestions ?
somethings not right. if it's sbs and you turn off the subs and it becomes 2d then you would be watching 2 half pictures side by side and 2d->3d wouldn't be of any use as it would be unwatchable.
if subs aren't listed by mkvmerge but in the video they are hardcoded and can't be turned off.
it can't be both ways.--
I found the problem . There was a dutch .srt file along with the mkv video in the same folder. Removing the .srt file solved the problem. I
also used MKVmergeGUI to remove the dutch audio . Now everything work as it should. I should inspected the movie folder more carefully.
Converting Left Right 3D MKV to Half SBS MKV
By TehBotolSOsro in forum Video ConversionReplies: 10Last Post: 3rd Apr 2012, 07:24 -
How to make subtitles work in a SBS 3d on my blue ray player?
By megatron031 in forum SubtitleReplies: 1Last Post: 25th Sep 2011, 01:25 -
half subtitles
By avenvtacloo in forum SubtitleReplies: 1Last Post: 22nd May 2011, 05:34 -
Getting only half the subtitles
By drschwartz in forum Newbie / General discussionsReplies: 3Last Post: 7th Aug 2010, 22:53 -
streaming anime no subtitles showing half the time/off screen
By thewhiteboy23 in forum Newbie / General discussionsReplies: 17Last Post: 18th Oct 2009, 13:46
