  1. Just wondering if someone can help me find ref & b-frames settings on Ripbot264 1.17 new ver.?
    Mar 2011
    Colombo
    I think that you can find those in the "Profiles" folder. You can open those preset's by dragging them into notepad and see for yourself.
  3. Did not find em there but Thanks for Ur reply.
  4. Please someone help me as I love the encode results from ripbot264 I have try couple of versions and after a couple of encodes they all star giving me out of sync problems please someone help me
    Oct 2011
    Turkey
    ı think ı has problems with dvd-rs because program cannot detect full time of the movide.it just take one vob file
  6. montevo Thanks for the advice but I think that the issue goes beyond that as I encode Jap anime from all kind of regions I also use xviD4PSP and have no issues with files but I kind of like better the final encode results of ripbot when it works you know.
    Oct 2011
    Turkey
    rapunzel, ı go back to 1.165 version of ripbot for dsvds.ı cannot find any way to detect right time in dvds.maybe new version of riobot detect my dvds.(ı am from turkey)
  8. Na Ripbot264 1.17 Communicates better with dvd's than older ver.
