So I am trying to put some converted video files into my iphone. I am using an Iphone 3GS with the 5.0 software. I am also using the newest version of times.
The files have been converted into MPEG4 and are using the H264 ACC codec. The file size can dimensions are in 640x480 but I have also tried smaller video dimensions. Bitrate: 744 kbps frame rate: 29 fps
I can get the videos into itunes. I can even play them in itunes but upon synching my phone with itunes and/or dragging the video files directly onto the listing for my phone on the left side bar, the video files will simply not go into my phone.
Does anybody have a suggestion how I can make this work?
Thanks!
hellfire45
i use this is it can import music, video, PC to iPhone
directly, and export files (music, movie, pictures, TV shows
you have to turn itunes off first for it to work
Portable Aiseesoft iPhone Transfer Platinum 6.1.22 Multilanguage
http://fcportables.blogspot.com/2011/11/portable-aiseesoft-iphone-transfer.htmlBulldog57
Some Videos Won't Sync to iPhone
By LegendaryLero in forum Newbie / General discussionsReplies: 2Last Post: 14th Jul 2011, 08:24 -
Difficulty playing 720p or higher videos on my notebook
By elcoyoteloco in forum Newbie / General discussionsReplies: 7Last Post: 14th May 2010, 06:52 -
Sending short videos to friends.
By Mark Wynn in forum Newbie / General discussionsReplies: 7Last Post: 8th Oct 2009, 12:08 -
The best ways to watch videos on iPhone
By Jeremiah58 in forum Portable VideoReplies: 4Last Post: 2nd Jul 2007, 02:21
