My avchd video(cooking shows) were copied (hddvr) @ a bit rate of 5.0 mb about 300 shows
all my new shows are @ 2.0mb
I can record about 40 to 42 shows on a bd single layer @ this rate
i would like to convert the other 300 to the same rate none of my software can do this
hddvr?
AVCHD is a camcorder format. Please explain. Then post Mediainfo text for a typical file.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Im using total media extreme to burn bluray this is the format there in and the play on bluray players
You could try shrink the m2ts video with avchdcoder or bdtoavchd. Or can't you shrink/reconvert with total media extreme?
software to batch convert m2ts format avchd to mts avchd?
By masterpug in forum Video ConversionReplies: 0Last Post: 14th Aug 2010, 02:06 -
What is the best software to convert AVCHD to SD?
By Endoking01 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 44Last Post: 12th Jun 2010, 22:32 -
Convert AVCHD
By mkrve in forum Video ConversionReplies: 36Last Post: 7th May 2010, 03:39 -
need to convert mpg to avchd
By mrgreaper in forum Video ConversionReplies: 5Last Post: 14th Aug 2009, 10:49 -
Convert AVCHD to AVI?
By i_c_e in forum Video ConversionReplies: 3Last Post: 12th Feb 2009, 05:23
