I'm breaking cherry on copying Blu-Ray discs. And as expected, I'm running into a snag.
I'm using two LG CP-40 external Blu-Ray drives; one for the source, one for the destinaton. I'm using Memorex and Verbatim blank Blu-Ray discs. I'm doing it on a Lenovo Ideapad V570.
I first tried copying from disc to disc, using DVDFab8. The software would not detect the destination disc.
Yes, there was a blank disc in the drive.
So I downloaded Slysoft AnyDVD HD & ripped the source disc. By the way, it's the 2nd part of the Swedish Dragon
Tattoo/Millenium trilogy, "The Girl Who Played With Fire."
I then installed IMGBurn & followed the instructions for use I found online under the following URL:
www.wesleytech.com/burn-blu-rays-a-how-to-guide-for-burningbd-r-discs/713/
I added the folder. Check. I clicked through all the prompts the tutorial said I would see. Check. But the software is not detecting destination media. The Burn button is grayed out.
Again, there is a blank disc in the destination drive. Both drives are visible in Computer.
I used both brands of black BD discs in either external drive, including the one which contained the source media. No love - neither of the blank discs are being seen. "Device not ready(medium not present)." And the source drive is functional. I was able to burn a standard DVD with it.
Can anyone steer me in the right direction in this matter? I'd appreciate it a lot. Thanks.
Just a guess - the BluRay you ripped is likely big enough to need to be burned to dual layer (BD-R DL) discs. You say nothing about what you have, but I'd make a guess that you only have single layer BD discs and that's a problem. If you want to shrink to single layer BD-R size you'll need to install BDRebuilder.
The content on the source disc is 23GB. The blank destination disc is 25GB - I guess that would be single-layer?
The ripped content came to about 24.5GB. So you're saying I'd still need a dual-layer disc in this instance? -
Capacity of a blu ray single layer is 23.3gb. But really depends on how you measure it. http://forums.highdefdigest.com/high-def-disc-faqs/17953-gb-vs-gib-explanation-storage-capacity.html
By the way, is this the drive you have? http://www.cdrlabs.com/Optical-Drives/LG-CP40NG10-Super-Multi-Blue-Slim-Portable-BD-Combo-Drive.html
If so, this is a slim, combo drive that can only read blu ray, not burn them. -
Yeah, it is. Wow, my newbie-ness is on full display, isn't it!! Man, I suck. BD-ROM - would have helped if I read the box a little closer! I bought two of them. And I'll be returning them tomorrow. Thanks for the help, fellas!
Copying a star trek series blu-ray disc
By ttheb1 in forum Authoring (Blu-ray)Replies: 1Last Post: 16th Nov 2010, 20:55 -
Introducing Ray in Blu Rendr - Digital Media Receiver Blu-ray Disc
By rayinblu in forum Newbie / General discussionsReplies: 6Last Post: 15th Apr 2010, 09:37 -
Blu-ray Disc screen capturing problems
By Animated Ben in forum Newbie / General discussionsReplies: 7Last Post: 22nd Feb 2009, 17:45 -
Can I rip Blu Ray Discs with LG Super Multi Blu-ray Disc and HD DVD-ROM Dri
By donpato in forum Blu-ray RippingReplies: 5Last Post: 5th May 2008, 16:05 -
My Sony Blu-ray player BDP-S1 does not recognize my Blu-ray Disc
By showgirl in forum Newbie / General discussionsReplies: 5Last Post: 2nd Oct 2007, 12:48
