Hi. I don't post here very often, but after trying many ways to fix this situation I've decided it's time to request help from the experts. Thank you so much in advance for your help!
Here's the situation: I created a DVD from an avi file using Corel DVD MovieFactory Pro 7. The DVD has just the avi file plus an srt subtitle file. No menus. The idea is that the DVD player starts playing the movie right away and shows the subtitles. And here's the weird thing: Everything appears to work fine regarding the subtitle file: Subtitles appear OK in the preview and, after burning the DVD, it works as expected on any video player software. But when I play the DVD in my Sony DVD player, there's no way I can make the subtitles to appear. The remote control allows me to turn subtitles on/off, but it simply doesn't work here. I've authored other DVDs with the same software and the result is perfectly fine. This is the first and (so far) only DVD with this kind of problem. Again, everything works flawlessly on my PC. But when I try to watch the movie in my bedroom using my DVD player and TV set, I can't make the subtitles to appear. Again, thank you in advance for your input on this issue.
That worked! I didn't know of the existence of such great DVD authoring software for free. Thank you very much!
Great! And you should thank _MrC_ , https://forum.videohelp.com/threads/277852-AVStoDVD-Support-Thread .
Subtitle Workshop Acting Weird
By Startropic1 in forum SubtitleReplies: 4Last Post: 14th Jul 2010, 22:51 -
Weird subtitle colors when authoring a DVD
By dexter30 in forum SubtitleReplies: 4Last Post: 22nd Feb 2010, 22:54 -
Problem expanding subtitle time with Subtitle Workshop
By Kaze105 in forum SubtitleReplies: 1Last Post: 11th Nov 2008, 23:16 -
weird subtitle error during authoring of a DVD
By michcio in forum SubtitleReplies: 2Last Post: 26th Oct 2008, 08:11 -
Very weird problem when replacing subtitle
By daemon22 in forum SubtitleReplies: 0Last Post: 6th May 2007, 09:16
