    Dec 2011
    Poland
    Hello,
    I captured VHS movie using my TV tunner, but unfortunetly the quality of the movie is not so good as I would like, every 10-15 frames I get bad looking belt in the middle of the screen like on the sample below:
    so my question is: how can I remove that kind of noise from my movie, maybe some kind of filter for Virtualdub will be suitable or any other usefull program for editing movies.
    I do not want to modify the movie frame by frame, that kind of method will be too time-consuming for me and I do not want to even consider it.
    Please help.
  2. Dvdropout should help assuming there is not fast moving motion and assuming this defect only last 1 or 2 frames
