Hi, Im new!! I was just wondering.. How can you tell a file from DIVX from RM?? How can you tell which is which?? I downloaded some DragonballGT episodes and I am confused if its RM or DIVX because I want to burn it and watch it on my dvd player instead the computer. Thanks for your help and i REALLY appreciate it.
It's easy. If it is an AVI then it could be Divx. RM files are RM files, they will have a RM or RAM extension, while Divx is an AVI extension. If you have an AVI load it into VirtualDub to see if it is a Divx and if so which Divx version was used to encode the AVI. To find out go to file and then file information after you have loaded the file.
Well... If you have a RM file, is it possible to convert it to DIVX and than burn it as VCD?
Let me start by saying I personally don't have much experience with RM or DivX. I think both are very low quality, especially the RM. As for converting you can use TINRA to convert the RM to another format. Whether or not you can convert it straight to DivX I don't know. I do know that TINRA isn't really that user friendly and is basically the only way to get it from RM to another format short of using a desktop capture device to record the audio and video as it plays on the desktop. There should be a TINRA guide to the left under Convert and TINRA should be in the tools section. Unless it is absolutely necessary I highly recommend staying away from RM and DivX unless you are really into those formats. The only situations I deal with Divx is when I download something already in that format and then I convert to MPG for VCDs. With my new computer I capture using the Huffy Codec in large format and then go straight to high bitrate MPG. That is just my personal preference and ability. Hope that helps some.
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 09:11 -
Reconverting Divx videos to smaller Divx files.. strange resolution
By arcooke in forum Video ConversionReplies: 2Last Post: 19th Jul 2011, 02:35 -
Beta Announcement: DivX Plus Web Player 2.1, DivX HiQ and HTML5 Support
By porfitron in forum Latest Video NewsReplies: 1Last Post: 23rd Nov 2010, 12:20 -
Philips DCP850 DivX overall quality (and DivX subtitle handling) question!
By mabhz in forum DVD & Blu-ray PlayersReplies: 0Last Post: 3rd Jul 2008, 18:59 -
Make an unplayable Xvid/Divx video play in a divx standalone Player
By AllenGorden in forum Newbie / General discussionsReplies: 4Last Post: 31st Dec 2007, 17:25
