I was wondering if it is possible to use a laptop screen as an external monitor to connect to a laptop. We all know you can connect a laptop to a monitor but is it possible to connect a desktop to use the laptop's screen?
Results 1 to 10 of 10
It's not practical. You would have to disassemble the laptop, get schematics for the data and power connectors, and build custom cables.
http://www.instructables.com/id/Laptop-Converted-to-2nd-Monitor/ -
YES
http://www.maxivista.com/
I have used it with XP but I have never tried it with Win 7CHEERS GARRY -
Forgot about remote desktop solutions. You just need a network connection then.
Even if the laptop is functional and you got one of those softwares to work, you'll get MAJOR lag & refresh problems. It won't be like using a native monitor, that's for sure...
Scott -
Actually, Jagabo's link above: http://www.instructables.com/id/Laptop-Converted-to-2nd-Monitor/
doesn't really convert the laptop to a monitor, it just repackages it as a PC running Linux. He says it was fast enough to play videos, so it may be good enough.
You could do this without any of the hardware mods to see how well it works.Once the monitor has booted Knoppix off of its CD, A program called MaxiVistaViewer (running under wine) takes over. The main system picks up the Viewer off the network, and with MaxiVIsta Server, creates the equivalent of a super fast RDP. The main system then stretches its screen onto the 2nd monitor. The second monitor runs well enough over the network that I can watch DVD's on it. Also, with MaxiVIsta I can "chain" up to 4 monitors together into one display, or even utilize it as a "Soft-KVR" using one keyboard and mouse to control all four systems.
Laptop LED screen acting up
By stantheman1976 in forum ComputerReplies: 6Last Post: 18th Nov 2011, 22:45 -
Laptop is showing nothing on screen.
By chewie8008 in forum ComputerReplies: 4Last Post: 26th Jun 2011, 23:56 -
Laptop LCD screen to TV
By cynikalhedonist in forum DVB / IPTVReplies: 4Last Post: 28th Apr 2011, 09:07 -
How to view laptop screen on TV?
By mikehende in forum Video Streaming DownloadingReplies: 9Last Post: 22nd Apr 2009, 10:26 -
Playstation 2 on laptop screen
By exill in forum Software PlayingReplies: 6Last Post: 10th Aug 2007, 16:00
