Hi! I make videos on youtube, edited with Sony Vegas Pro 11. I have many, many videos, mostly in 720p and I've never had a problem. But this time, I recorded a video on my iPhone 4S in 1080p. While editing it in Sony Vegas, I noticed in the preview video, it appeared a little choppy. I didn't think much of it and continued to render. But the rendered video had the same problem: The audio and title and everything is fine, except the video is choppy, skipping many frames, and playing at only about 1.5 FPS. In Sony Vegas, it gives me the frame number, but than puts an ellipsis, and shows a different frame and frame number. I have tried various templates, including switching back to my old standby of 1280x720 at 29.970 FPS progressive. Still no avail. I also tried switching the field order, also no success. Thanks in advance for your help.
- Ian
By the way, most often my video files have been in .M2TS, whereas this file is in .MOV. Thanks!
Did you try it in Quicktime? Have you updated Quicktime lately?
Vegas uses the QT player to decode Apple files. If there's a problem, it's because Apple tries to through a wrench in there for Windows users from time to time to get you to upgrade QT so they can grow more into your computer. -
Ok I updated it. It's a little bit better but the video is still very choppy.
http://www.kiva.org/about -
did you try converting the orig. footage before importing into vegas to see if that would make a difference? it does seem to appear that the iphone 4s doesnt record at a constant framerate but rather selects it depending on low light conditions (from 24 to 30), with low light giving considerably lower framerates
Knowing how Apple operates, I'm sure it will play fine in FCPX.
I just uploaded a clip to facebook and it's fine. I'm going to go ahead and upload the full video to youtube and see what happens. Still laggy on my PC, and my PC is pretty powerful.
"Video: Stream attributes could not be determined" in Sony Vegas
By bloodshed in forum Newbie / General discussionsReplies: 41Last Post: 6th Nov 2012, 06:12 -
Output of both m2v AND ac3 during single "Render As" event in Vegas?
By Smells_Like_Feet in forum EditingReplies: 3Last Post: 28th Oct 2011, 19:08 -
Sony Vegas Pro 10 - video/audio out of synch after render
By Acester47 in forum EditingReplies: 4Last Post: 1st Jul 2011, 14:06 -
[Sony Vegas Pro 10] GPU "acceleration" = slower encode?
By DragonQ in forum Video ConversionReplies: 3Last Post: 11th Jan 2011, 15:32 -
Best render for 4:3 video using Sony Vegas pro 10 for youtube
By fuzzblaster in forum Video ConversionReplies: 0Last Post: 9th Jan 2011, 13:18
