I have been using SW a while now to re-sync subs. But I am having trouble loading an AVI file. It crashes everytime, despite changing the file name.
I have a few of the same type files in this series that also crashes. The rest has no problem opening. Some differences between the good and bad:
Bad Good
Aspect ration is 16:9---------------vs 4:3
Codec is Divx5 or DV50-----------vs XVID
Bad load Ep 45
Video
Format : MPEG-4 Visual
Format settings, BVOP : 1
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (H.263)
Muxing mode : Packed bitstream
Codec ID : DX50
Codec ID/Hint : DivX 5
Duration : 57mn 58s
Bit rate : 1 486 Kbps
Width : 1 024 pixels
Height : 576 pixels
Display aspect ratio : 4:3
Frame rate : 29.970 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.084
Stream size : 616 MiB (88%)
Audio
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : 2000
Duration : 57mn 57s
Bit rate mode : Constant
Bit rate : 192 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Delay relative to video : 21ms
Stream size : 79.6 MiB (11%)
Alignment : Split accross interleaves
Interleave, duration : 33 ms (1.00 video frame)
Interleave, preload duration : 500 ms
Good Load Ep 05
General
Complete name : F:\K Drama\Dae Jang Geum\Dae.Jang.Geum.E05.avi
Format : AVI
File size : 700 MiB
Duration : 1h 1mn
Overall bit rate : 1 601 Kbps
Director : R.F(RJ)
Writing application : Nandub v1.0rc2
Writing library : Nandub build 1853/release
Video
Format settings, BVOP : No
Codec ID : XVID
Codec ID/Hint : XviD
Duration : 1h 1mn
Bit rate : 1 399 Kbps
Width : 576 pixels
Height : 432 pixels
Frame rate : 23.976 fps
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.235
Stream size : 612 MiB (87%)
Audio
Format : AC-3
Codec ID : 2000
Duration : 1h 1mn
Bit rate : 192 Kbps
Bit depth : 16 bits
Stream size : 84.0 MiB (12%)
Interleave, duration : 42 ms (1.00 video frame)
Tried MPEGModifier to change the aspect ratio. But something else is causing the crash.Don't know what else to do.
many thanks
Results 1 to 1 of 1
Subtitle Workshop Crashes
By randy3101 in forum SubtitleReplies: 5Last Post: 6th Jun 2012, 16:32 -
Subtitle (Workshop) and mpg video
By cyrax2006 in forum SubtitleReplies: 10Last Post: 6th Nov 2011, 15:17 -
Subtitle Workshop crashes upon loading subs
By mystic818 in forum SubtitleReplies: 9Last Post: 17th Mar 2011, 07:51 -
Subtitle Workshop does not show video
By aslan in forum SubtitleReplies: 2Last Post: 1st Apr 2009, 08:38 -
Subtitle Workshop 4 crashes when loading subtitle file
By Batou in forum SubtitleReplies: 0Last Post: 26th Mar 2009, 07:57
