I've been transferring VHS to AVI (for editing then to DVD) for a few years, and my old ATI AIW AGP card into VirtualDub worked great.
But this year I upgraded my system and the new mobo doesn't have AGP, so I decided to try capturing via USB with an ATI TV Wonder HD750. But I'm having difficulty getting a good transfer. First of all, AFAIK the device is only be able to capture at 720x480 UYVY, and huffyuv compression is not available so the files are (obviously) huge. I'm also getting a lot of dropped frames, far more than I ever had using the PCI card, although changing the audio settings helps.
FYI, the software that comes with the device only seems to capture to MPEG.
So I'm looking for any tips using this device before I get frustrated enough to return it.
				Results 1 to 11 of 11
	Is the version of Virtualdub you installed 32-bit or 64-bit? The version of HuffYUV installed must be 32-bit or 64-bit to match.
 AmaRecTV http://amamaman.web.infoseek.co.jp/english/amarectv_e.htm is alternative capture software that also works with many different capture cards and allows the use of HuffyUV and a few other lossless formats. It is 32-bit software, so install 32-bit versions of the compressors you want to use with it.
	Well, now I'm able to capture with huffyuv compression, but the capture consistently drops 6 or 7 frames when it starts, and the audio does not sync (meaning that when I play back the AVI, the audio is ahead of the video). I'm betting that there is an adjustment in v-dub for audio sync, but I never had this problem with my old AGP card and I'm wondering if I'm just running into the limitations of a USB device?
 Any tips would be appreciated.
	The instructions in this post might help: https://forum.videohelp.com/threads/315378-need-help-with-ati-TV-wonder-650-USB-no-soun...=1#post1995236
	Thanks, this looks good. I did a test capture using these tweaks that turned out well, so I'll try these settings for the next VHS transfer.
 My biggest problem now is audio sync.
 Claudio, the settings in your tutorial don't work with my USB capture device, although I think that increasing the buffer will probably help... I'll let you know.
	Compatibility mode was removed at some point. If you look at current versions, F5 and F6 map to the same menu option.
	Thanks for reminding me, I see for Dec 2011 a new VirtualDub (1.9.11). I had 1.9.4 a month ago, hit F5 by accident and lost sync all over the place. Downloading the new VDub now.   Last edited by sanlyn; 21st Mar 2014 at 09:11.
  Vdub: Screen CaptureBy dylz in forum Capturing and VCRReplies: 6Last Post: 12th Jan 2011, 17:24
  multiple trouble with audio while working with VDub 1.9.10By sorophx in forum AudioReplies: 4Last Post: 28th Dec 2010, 23:20
  VDub setup for VHS CaptureBy HDClown in forum Capturing and VCRReplies: 16Last Post: 27th Apr 2010, 04:48
  split fields in vdub captureBy greenbag in forum Capturing and VCRReplies: 0Last Post: 18th Jan 2009, 23:50
  Not Working?? Capture with BFG 7800GTX and vDubBy DW in forum Capturing and VCRReplies: 0Last Post: 15th Jan 2008, 16:12
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
