Does anyone know if DVDFab, or some other software, can do this?
My dilemma is that I'd like to have an ISO with all the Special Features on the disc. and include all the menus, but I don't want the main movie included. I want to keep the file size down, plus I want the main title to be played in MPC-HC with MadVR as it looks quite a bit better. But, as we know, MPC-HC does not like BD menus, so I'm forced to use PowerDVD for mall BD's where I want to see the menus.
Any ideas?
Tried Clown_BD BD Copier? I think you can deselect the main movie and keep the rest.
And I'm moving you to our blu-ray ripping/reauthoring section. -
I'd like to know how to encode a BD menü + extras only (without the main movie). Clown_BD BD Copier only copies, not encoding. thx
You can strip the BD menu + extras and then encode. I do not recommend DVDFab for "encoding"/trans-coding. I would strip/copy the specific files you want and then use another software for encoding.
And yes, the paid version of DVDFab has the option to copy/strip everything without the main movie. -
Unless it has drastically changed functionality recently I don't think BD-Rebuilder can help at all with what is proposed by post #3.
Rip DVD including subtitles using vlc
By skeptic_always in forum LinuxReplies: 10Last Post: 22nd Sep 2013, 21:19 -
Including multiple audio streams in rip
By rocks911 in forum DVD RippingReplies: 1Last Post: 9th Dec 2011, 09:39 -
DVD to iPoD/PSP/Cell phone/PCP including subtitles using DVDFab Platinum
By Baldrick in forum User guidesReplies: 6Last Post: 14th Nov 2009, 14:09 -
Bolt – Can you copy the main movie title to the disc?
By coody in forum DVD RippingReplies: 10Last Post: 27th Mar 2009, 17:42 -
DVDFab Platinum - copying just one title/chapter
By ronhammond71 in forum DVD RippingReplies: 11Last Post: 4th Jun 2007, 16:58
