I went on and got tmpgenc plus. Im converting avi to mpeg1 vcd.
Can anyone tell me the correct settings I need to enter for it to be
the gtreatest quality vcd.
Also when I close the wizard and open settings, everything is locked.
I cannot change anything
Click load, go to extra, select the unlock file and go back to settings. You now should be able to change the settings anyway you want them. As to what is the ultimate setting..... that's up to you (depending on wheter you want to watch your movies on your computer or on your tv (stand-alone dvd-player). My advice is to just experiment and try all the different formats. I'm currently very sattisfied wih SVCD.
Good luck, Jack
Pegasys released TMPGEnc Video Mastering Works 5 (aka TMPGEnc 5.0 XPress)
By roma_turok in forum Latest Video NewsReplies: 6Last Post: 24th Jun 2011, 15:42 -
Tmpgenc Plus & TMPGEnc Batch List Creator help Please
By VOYAGER2009 in forum Video ConversionReplies: 2Last Post: 4th Jul 2010, 07:57 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 13:23 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 02:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 15:07
