I dont know where to post this question.
I searched all the regions hacks for Sony's and found one that almost worked.
I followed these instructions exactly and the screens come up except on the last screen where it displays the region, there is no method to change the region. If I select, Next, it goes away. If I type in a number it goes to the previous screen, any help. I really would like to play a DVD from England on a US Sony
-Turn TV onto input channel (the one used to watch DVDs normally)
-Press Title, clear, power on DVD remote in rapid succession
-Go to 0 for Syscon Diagnosis
-Go to 2 for Version
-Go to 5 for Region
-Enter the region desired (01-05). This part just doesn't work, no way to enter or change the region.
thanks
Hacks for your player are here: https://www.videohelp.com/dvdhacks/sony-dvp-s360/428. ...But one reply said a mod chip was required for them to work. Some countries require that all DVD players can be made region free and players sold there may have a mod chip or different firmware which allows it. The same model sold in the US may not be hackable.
Welcome to VideoHelp. A couple of suggestions about using this forum... Posting a question about hacking your model in threads about region-free hacks for other models is unlikely to get you a useful answer. Plus, cross-posting and thread hijacking violate forum rules.Last edited by usually_quiet; 29th Dec 2011 at 14:03.
thanks for the response. I checked t hat thread and was unable to post to it, it said it was not a forum, so I dont know where to post. I think its not possible based on that thread, that I need a mod chip whatever that is, and another person said it was not likely to be able to change region on a US Sony.
He suggested ripping the dvd to another disc. I might try that.
Is there is another forum for me to post to, I would be glad to but I can't figure out where that would be. -
So you want to play Region 2 dvd's (England) in a Region 1 dvd player (U.S.)...
Ripping the R2 dvd to your PC and burning back to a DVDR will remove the region coding, but there is another issue....
The U.S. is NTSC video format and England is PAL video format, and i doubt your $ONY dvd player will convert PAL to NTSC.
$ony's are notorious for throwing up a message that say's the dvd you are trying to play is the incorrect region even when it is region free just because it is in PAL format and not NTSC. -
Thanks for the reply.
I will try ripping it and burning it but it sounds like I am out of luck with my sony player either way.
I will be able to watch it on my pc when I get one.
just wanted to try it on the tv.
its a dvd t hat was never released in the states
looking for hack for region 1 Sony DVP-NC615
By occhiv in forum DVD & Blu-ray PlayersReplies: 4Last Post: 18th Mar 2019, 21:11 -
Region Hack for Sony DVP-SR500H?
By Tank251 in forum DVD & Blu-ray PlayersReplies: 5Last Post: 8th Oct 2012, 08:29 -
Sony DVP-NC9100ES region hack
By egidijus7777 in forum DVD & Blu-ray PlayersReplies: 3Last Post: 29th Dec 2011, 14:18 -
Sony DVP-NS700H region hack help
By rskanocz in forum DVD & Blu-ray PlayersReplies: 2Last Post: 12th Jul 2010, 14:47 -
All Region Hack for Sony DVP-NS708H -_-
By BloodySunday in forum DVD & Blu-ray PlayersReplies: 2Last Post: 23rd Nov 2009, 08:44
