I'm a VERY frustrated mom who is trying to make flv copies of her son's video project. I've converted it from prel to flv (honestly don't know I did it).
I can play the file perfectly on my desktop (where both the prel and the flv were created), but when I burn it to a disc and play it on my laptop, it will not play correctly. There are glitches in both the video and the audio.
What am I doing wrong? Or what can I do to make a good flv disc. The actual disc has to be submitted for the project.
HELP!!!!!!!!!!
Sincerely,
KFain/Cincinnati
Can you give more info about your flv files? You can use mediainfo and open the flv to check the details like resolution/video size, video codec, etc.
And try play with another software player like VLC Media Player and see how it works. -
downloaded VLC Media player on the laptop and the cd still glitched in the same spot
It's not any flv, it's an avi with dv video. Your cd reader might be too slow for the high data rate. Reconvert to smaller/more compressed format like a real flv or mp4, use for example freemake video converter.
Are you saying the file isn't an actual flv file? Can I convert it from real player? The original prel file seems to be damaged now. Thanks so much.
OK. I made a new flv. What program should I use to burn the cd? Or can I just drag and drop it?
DV won't play correctly anymore.
By xtremeD63 in forum Software PlayingReplies: 52Last Post: 9th Apr 2011, 14:08 -
dvd won't play on player but will on computer
By bubbadss in forum Authoring (DVD)Replies: 9Last Post: 28th Apr 2010, 03:49 -
Burned DVD from TV and won't play in computer
By dnlowe in forum DVD & Blu-ray RecordersReplies: 4Last Post: 12th Sep 2009, 18:41 -
FLV converting problem: video won't play
By dombi in forum ffmpegX general discussionReplies: 0Last Post: 1st Apr 2009, 03:51 -
dubbed DVD+R won't play on my computer
By TraceyG58 in forum Authoring (DVD)Replies: 3Last Post: 17th Feb 2009, 16:51
