[SOLVED]
is there a way to manipulate the shortcut so that i can drag it into virtualdub so that it can open the video file ?
-history-
i have a tool that creates very short avisynth scripts..couple lines worth. the tool just helps me open/view the more advanced video files like flv, mpeg2, move, mkv, avc, etc. but without having to go through the complicated steps of preporation. just a simple drag/drop of the video file into the tool and it creates the script. ok. so i have the tool always write the same script filename: video.avs and i put it in the root c:\ drive so its that much simple to get to w/out navigating to complicated folders.
-the problem-
occurs when i go the next step, which is, drag the video.avs file into virtualdub. what i'd like to do is copy the video.avs file as a shortcut on my desktop. the file is no longer recignised. vdub see's .lnk as an unrecignised file. and that's the problem.
other than the mentioned problem, the tool works great. i can drag almost any video file into its window, (it writes the script on screen) and i can do this with many videos very quickly. this is something i always imagined but didn't have the time or energy to start the project.
thank you in advanced.
EDIT: i found an alternate method which saves me from even more juggeling of things.
by finding a windows handle, i.e., virtualdub's, we can send keystrokes to virtualdub's menu and open the last file. this is the method i am using to open the same avs script although the script has a different video filename. at the next juncture, i might look into creating a video viewer built-in. but the method i'm using now is more than enough for my needs.
in case it helps others in similar situation, here's the code i used for my tools purpose:
Code:interface type TForm1 = class(TForm) procedure OpenVideo(WinName: string); private { Private declarations } AV: TStrings; public { Public declarations } end; var Form1 : TForm1; implementation procedure TForm1.OpenVideo(WinName: string); var fWindow: HWnd; // window handle...i.e., virtualdub begin fWindow := FindWindow(pchar(WinName), nil); if IsWindow(fWindow) then begin // test if wind exist.. SetForegroundWindow(fwindow); // ..set focus the found window keybd_event(VK_menu, 0, 0, 0); // alt key press keybd_event(Ord('F'), 0, 0, 0); // f key press keybd_event(VK_menu, 0, KEYEVENTF_KEYUP, 0); // release alt+f key keybd_event(Ord('1'), 0, 0, 0); // 1 key press, from File menu end; end;Code:procedure TForm1.vdubClick(Sender: TObject); begin // open virtualdub, and send keystroke for \File\1.default.avs OpenVideo('VirtualDub'); end;
Results 1 to 1 of 1
[solved] VDub, Win7 x64, Multiple passes?
By Keeyu in forum EditingReplies: 2Last Post: 12th Jan 2011, 04:01 -
NEWBIE - AVS Video Converter - How To Convert What Format To Use?
By ameliajune in forum Newbie / General discussionsReplies: 2Last Post: 30th Sep 2010, 16:14 -
How to restore desktop shortcut arrows and folder/file icons.
By lelouch283 in forum ComputerReplies: 1Last Post: 6th Sep 2010, 22:24 -
Remove "My Bluetooth Places" Shortcut On Desktop
By lowlow42 in forum ComputerReplies: 12Last Post: 26th Apr 2010, 09:17 -
What's a good freeware program to convert AVS to video?
By jk318 in forum Newbie / General discussionsReplies: 14Last Post: 27th Aug 2007, 18:42
